Fuel stepper motor going out - Will gas warning light still come on?
#21
According to my cluster:
Fuel is beyond empty at all times, the needle hangs down most of the time.
Engine temp is ice cold at all times.
Battery is dead at all times.
Engine idles at -500 RPMs at all times
Oil level is over flowing at all times.
I've been in this position for over a year now, just got the stepper motors in from Amazon and plan to do the fix in the next few weeks.
The gas light does still turn on at the appropriate time and if you have the message center, it will warn you when you are at <50 miles.
Good luck!
Good luck!
Good luck with the fix and keep me posted!
#22
Anytime you fill up, take the keys out of the ignition. it will register the correct level immediatly when you put the keys in afterwards.
#23
I am not sure about freak2180, however, I always take my key out of the ignition when filling up. I've only experienced where the fuel gauge would stick at the half way mark. When I add a half tank of gas, the gauge would go way passed the full mark.
#26
I am not sure, however I would think so. My thermostat gauge only works when it is 60 degrees or warmer. As long as my radiator fan keeps kicking on and cooling my engine, I know everything is working fine. I also had it tested, when I had my clutch replaced and the temperature is in the correct range.
ShaneB26154
35
03-04-2021 04:05 AM
