Retro Solutions HID kit help
I think as long as the HID bulbs are sufficiently capped you can run that setup without problems.
Glad you got things figured out Mad, looking forward to your write-up.
I'd need to see one on a mustang, maybe it would surprise me - I am going off of experience from seeing it on a dozen other cars with non projector housings. one of my largest pet peeves on the road is getting blinded by them. lol
Been blinded by every type of civic/tiburon/cobalt with those non-capped HIDs to the point where I actually thought projectors were the only OEM solution. But low and behold, capping does actually do a sufficient job.
I would do it yesterday if it weren't for the fact that police in my parent's town already seem to have it out for any car flashier than a Solara.
I can ensure you, as long as you cap the bulbs, the cutoff is pretty good. I imagine my cutoff isn't quite as defined as some I've seen online due to the headlight tint I'm rocking. However, I can confidently say that I'm not blinding anyone.
As I said earlier, I have had the kit from Retrosolutions (35W) for many years. My car came with the black caps over the end of the bulbs. I probably haven't been "flashed" by oncoming cars a half dozen times in all those years. The light that dazzles oncoming cars comes out of the end of the HID discharge tube, hence, the capped setup is not a problem.
Kind of a cool thing is that Retro Solutions offers an option for cars without these built in caps. They will dip the ends of the HID discharge tube in a ceramic coating which performs the same function.
Retro Solutions is really a top shelf company. They have a lifetime warranty on their entire kit. I would highly recommend their products over the cheapy kits from places like EBAY.
MAdStang - I agree, the capping is well worth it. I don't have all those shadows and light lines you get from other kits without caps.
Cutter - I also have the 55, and have never been flashed for being too bright. And light output is awesome.
One thing I'll add for anyone adding an HID kit. Make sure you adjust your lights accordingly. Sometimes, when adding a kit, your pattern can be higher and that's what will blind oncoming traffic. Be mindful where your pattern is. Take before and after measurement of where the beam is. Maybe something as simple as marking a spot on the garage door with a tape line.
jwog666
12-27-2021 08:09 PM
