Would a bad install cause major vibrations? I only get the vibrations going 80mph or faster. The faster I go the worse it gets when I let off the gas. It only happens when I let of the gas not during acceleration.
i wouldnt think a bad install would cause what you described, but i could be wrong so someone correct me if so. i thought i read somewhere bad vibrations could be coming from a driveshaft issue? not sure though.
Moose is correct. The clocked your DS wrong. Slacker installers.......you always mark the DS so you reinstall it exactly the same. Make sure you clean all the locktite off too. You want a clean surface. That should clear up your issue.
