Sponsored by:
Sponsored by:
UPR vs JLT Catch Can
Old 03-05-2013, 05:16 PM
Goldenpony
Goldenpony's Avatar
Default UPR vs JLT Catch Can
I ran a UPR catch can on my '06 GT for several years and with the exception of the hoses, I was well satisfied with it. I would empty it every 2500 miles and it was regularly 3/4 full of oil.
Recently I decided to switch to the JLT catch can, simply because I liked the factory type pre made hoses. I also liked the black anodized finish. I also liked the over all looks of the JLT unit. I sold the UPR can.
I just removed the new can for the first time at 2200 miles and I was shocked. It had maybe 1 teaspoon of oil. Is the JLT can that much less effective than the UPR? Damn, I wish I had the old can back. Has anybody else had a similiar experience? If I hadn't run the UPR can for years I guess I would never have known.
Goldenpony is offline
Old 03-05-2013, 06:06 PM
CMcNam
CMcNam's Avatar
I have the JLT as well and am also rather disappointed by how much it doesn't catch. I pulled it off and looked the side going into the manifold and there's a bunch of oil on that side!
CMcNam is offline
Old 03-05-2013, 06:10 PM
mapitts
mapitts's Avatar
Put a small wad of stainless steel wool in it and it will pick up more. Just enough to losely fill the can. You will have to dump it more often, but you will be suprprised at how much more you do catch.
mapitts is offline
Old 03-05-2013, 06:27 PM
Roy_R
Roy_R's Avatar
DON'T do that...that stuff will be sucked into your engine!!!
https://mustangforums.com/forum/2005...with-pics.html
Roy_R is offline
Old 03-05-2013, 07:05 PM
Esch
Esch's Avatar
I have a brand new JLT catch can that I'm going to install once the weather clears and my car comes out of hibernation. Dang, hope I didn't go with the wrong brand.
Esch is offline
Old 03-05-2013, 07:32 PM
mapitts
mapitts's Avatar
Not if you use the larger stuff. Really about the size of medium drill shavings in a ball. If it was the smaller stuff I would agree. SOS pad size. I get mine at work. We use it as a purge diffuser when welding stainless, Monel, or Inconel pipe. It works and people have been doing it for years. I poke one ball down in and change it every other oil change. Breaks the turbulence and allows the oil to settle and run down into the catch can.
Edit; I should not have said SS wool. A SS scrub pad is about the size I am talking about.
mapitts is offline
Old 03-05-2013, 08:11 PM
Diabolical!
Diabolical!'s Avatar
Glad I read this. You've sort of confirmed what I've always suspected. I have a Moroso personally, and it catches a LOT. After the Moroso and Stef's cans became a popular DIY mod, it seems like the market was quickly flooded with imitators. UPR's unit seems to work very well, but some of the others leave a lot to be desired.
Diabolical! is offline
Old 03-05-2013, 10:29 PM
SON OF 68
SON OF 68's Avatar
I heard this about JLT before I bought a can. This info swayed me to buy the UPR. It also catches a good amount about every 2K.
SON OF 68 is offline
Old 03-05-2013, 10:38 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
If you'd like to get back into a UPR can, I'll get you a discount.
For what it's worth, if you're super OCD with your mods (like I am sometimes) you could customize the UPR can. Black anodize or powder coat it. Have custom lines made whatever shape and color you want. And so on. Don't get me wrong, I'm running my UPR can as delivered. I'm just saying that if you want to personalize it, you could do that. Functionality is more important than looks, but you can have both!
UPRSharad is offline
Old 03-06-2013, 08:33 AM
IGO 202
IGO 202's Avatar
Interesting post GP.....
I read before ordering my JLT from AM, everyone seemed pleased with the results but most probably did not have the comparison info that you have.
I want what works best, function over form.
My JLT is on it's way to me, not sure about AM's return policy for refund but I see that they carry the Moroso brand with a specific bracket for the '11-13's. I might be able to swap if I can get some results from a Moroso separator.
Anybody using one?
If I can't find out anything with the Moroso I'll ask for a refund and go with the UPC since it's obvious that it works.
Thanks,
Dan
IGO 202 is offline
Quick Reply: UPR vs JLT Catch Can
