Sponsored by:
Sponsored by:
2010 Mustang GT Grinding Gears
Old 03-28-2013, 06:58 PM
playerone
playerone's Avatar
Default 2010 Mustang GT Grinding Gears
Straight out of the Ford dealer ship, where the service manager and the ford field engineer state "Operating as designed"
playerone is offline
Old 03-28-2013, 06:59 PM
playerone
playerone's Avatar
Links to 2 service documents in you tube description
Old 03-29-2013, 07:05 PM
playerone
playerone's Avatar
bump,
Anyone have any contacts at ford corporate, so I can actually get this resolved?
Old 03-30-2013, 01:53 AM
draxxus131
draxxus131's Avatar
There is a young Ford Rep somewhere around one of these sights floating around she goes by the name Deysha on mustangsource.com . She's a really cool person just make a thread on that website under warranty/service issue. She can most likely help you out.
I wish you the best of luck, Excelsior.
draxxus131 is offline
Old 03-30-2013, 02:44 AM
Rudolph Hucker
Rudolph Hucker's Avatar
sounds normal to me dude
i have a 2007 v6 manual thats only gone 12k miles..mines sounds the same..if i'm right the gearboxes on these cars are made in china...
imho the gearbox on these stangs is about the worst manual box i have ever had..all my other cars have had a silky smooth gear change..
i say thats the way it is i'm affraid
Rudolph Hucker is offline
Old 03-31-2013, 12:03 AM
20binafd
20binafd's Avatar
its not the gearbox, that stock shifter is just a little rough around the edges. If it bothers you so much, look into a MGW shifter, I hear its a great upgrade to the stock shifter. Also don't try to shift into first while moving, that might be your issue. And no, the tremec isn't made in china, don't know what Rudolf is smoking.
20binafd is offline
Old 03-31-2013, 09:16 AM
slickman
slickman's Avatar
I will bet this is a the clutch line. I had a problem very much like this only at high RPM. I'm not sure if the clutch line going to the slave cyl is the same diamater in 2010 but in 2008 it was too small. Its only like .178 ID which did not allow enough fluid to move the clutch fast enough under some conditions. I replace it with a after market that was .250 ID and the problem was gone totally.
If you have the clutch depressed all the way, not moving very fast or at all, it should not grind at all. Which is what it looks like to me, your being very easy and slow with it.
Just a thought to look into, simple and inexpensive fix. Other than that, it sounds like it a clutch issues for sure...
slickman is offline
Old 04-02-2013, 07:37 AM
FordService
Official Ford Rep
FordService's Avatar
Originally Posted by playerone
bump,
Hello playerone,
Welcome to the forum! My name is Deysha with Ford Service. I’d like to escalate this to the customer service manager for your area. Please make an appointment and PM me with your VIN, dealer, mileage, full name, and best daytime number so I can help.
Thanks for the mention, draxxus131!
Deysha
FordService is offline
Old 04-03-2013, 03:32 PM
playerone
playerone's Avatar
Keevis, Angela (A.)
3:53 PM (34 minutes ago)
to me
John,
Due to having a Field Service Engineer involved and advising that is a normal operating concern I can only suggest that you return to your selling dealer. As I am not able to provide any additional assistance. Also additional information is available in your owner’s manual about your consumer rights.
Old 04-03-2013, 03:56 PM
modru2004
modru2004's Avatar
as a fellow owner of a 2010 mustang gt manual i can tell you that that is NOT normal with absolute certainty.
wheres you clutch engagement point at?
modru2004 is offline
Quick Reply: 2010 Mustang GT Grinding Gears
