Sponsored by:
Sponsored by:
Best struts for Eibach pro kit springs?
Old 04-13-2013, 12:51 PM
JayBeStangs94
JayBeStangs94's Avatar
Default Best struts for Eibach pro kit springs?
I'm definately due for new struts. I have probably used my springs for about 3,000 miles now and the car alone has about 75k. I'm considering going with the koni yellows front and rear struts. What would be the best match for the eibach pro kit springs?
Thanks
JayBeStangs94 is offline
Old 04-13-2013, 01:22 PM
yellowneck86
yellowneck86's Avatar
I've heard good reviews on the Koni yellows. Ive been recommended in the past to get Tokico D specs and Strange.
yellowneck86 is offline
Old 04-13-2013, 05:38 PM
05 Mustang
05 Mustang's Avatar
Both the Koni Yellows and Tokico D Specs are great.
05 Mustang is offline
Old 04-13-2013, 07:03 PM
mayo
mayo's Avatar
Save the coin and go with the koni str.t's
Yellows are for the track imo.
mayo is offline
Old 04-14-2013, 01:19 PM
JayBeStangs94
So the Koni's and the Tokico D specs are a good match up for the springs. I'll have to check out what they have to offer. And whats the difference between the yellows, sport, and str t's? Anything else I should consider when buying struts, i.e. strut mounts, panhard, etc?
Old 04-14-2013, 07:48 PM
Roy_R
Roy_R's Avatar
What he said...
Roy_R is offline
Old 04-15-2013, 09:20 PM
JayBeStangs94
I'm thinking ill go with the Koni Sports, they're adjustable, and ride better than the str.t's
Old 04-16-2013, 03:17 AM
moosestang
moosestang's Avatar
My motorcycle has adjustable suspension and sometimes I wish it didn't. You may find you are constantly adjusting it and never quite happy.
I'll be doing nonadjustable for the mustang. Get the gt500 strut mounts.
moosestang is offline
Old 04-16-2013, 07:25 AM
mfergel
mfergel's Avatar
Haha. Well, seeing as how I have a Buell as well I set mine once and it hasn't changed since.
mfergel is offline
Old 04-16-2013, 11:18 AM
mayo
mayo's Avatar
Most will tell you that the softest setting on the yellows = the str.t's jay.
I don't think they ride better than the str.t's, they can be adjusted for stiffness which I can tell you...is not needed for street performance and will not ride better, just enhance handling. The question you need to ask yourself is, do you push the handling of the car enough to justify the cost.
mayo is offline
Quick Reply: Best struts for Eibach pro kit springs?
