Sponsored by:
Sponsored by:
Lowering Springs. What's Needed?
Old 04-21-2013, 02:02 PM
NateKR
NateKR's Avatar
Default Lowering Springs. What's Needed?
I'm looking to lower my GT. I want to go down an inch. American Muscle has a set of Ford Racing P Springs. I've got all the tools needed and what not but is the bump stops and camber bolts needed for the install? I figured if I went lower the camber bolts would be needed but will they make that big of a difference without them only going down an inch?
NateKR is offline
Old 04-21-2013, 04:28 PM
dennisafrompa
dennisafrompa's Avatar
NO. I've gone 1 1/2" and can still get a good alignment in my Bullitt. You should get new strut mounts though, mine are HD Steedas.
dennisafrompa is offline
Old 04-21-2013, 04:44 PM
CMcNam
CMcNam's Avatar
If you're only lowering an inch you most likely don't need any extra parts. If you want to kill two birds with one stone, you can replace your strut mounts with adjustable camber plates and then you won't have to buy camber bolts either. I don't think it's necessary with a one inch drop though.
CMcNam is offline
Old 04-21-2013, 07:05 PM
808muscle
808muscle's Avatar
Everything I have read says no camber bolts or relo brackets needed with p springs. My buddy put them on his boss and it looks good. So good I am thinking about them too. Lets see those pics when you get them installed.
808muscle is offline
Old 04-21-2013, 07:13 PM
mayo
mayo's Avatar
I went with the p's and here is what I used...
P springs
GT500 strut mounts
j&m adj panhard bar
koni str.t's
handles like a champ even with oversized rear staggered tires.
mayo is offline
Old 04-22-2013, 07:14 AM
05 Mustang
05 Mustang's Avatar
you'll be just fine with only the springs
05 Mustang is offline
Old 04-22-2013, 10:27 AM
AMWill
Former Sponsor
AMWill's Avatar
Just to confirm. You'll be fine with just the Ford Racing P Springs, like these guys mentioned. There's really not need for anything else, however I always suggest upgrading to the GT500 strut mounts since the factory units seem to fall apart easily.
Hope this helps!
Shane
AMWill is offline
Old 04-23-2013, 10:42 PM
mustangspotential
mustangspotential's Avatar
I really want to lower my car but I don't know how to do it and don't really want to mess with anything. It seems like more parts are needed then just the springs if I found them at good deal. I would still lose out having them installed at a shop.
mustangspotential is offline
JonnyBlazeGT
11-03-2015 01:10 AM
zachary1988
09-01-2015 07:58 AM
01moostanggt
08-17-2015 01:22 PM
defarmer
08-13-2015 06:40 AM
ccwebb
08-11-2015 06:47 PM
Quick Reply: Lowering Springs. What's Needed?
