Sponsored by:
Sponsored by:
stage 3 clutch, misss 2nd and 3rd
Old 04-23-2013, 02:50 PM
nick2010gt
nick2010gt's Avatar
Thumbs down stage 3 clutch, misss 2nd and 3rd
Im needing some help, I have a 2010 gt with a 5 speed. I burnt the factory clutch up at 19k miles doing burn outs and had to replace it. I put a stage 2 centerforce clutch in and have been having problems hitting 2nd and 3rd in real high rmps with the traction control off. any suggestions??
nick2010gt is offline
Old 04-23-2013, 03:05 PM
2005Redfire6
2005Redfire6's Avatar
Learn how to shift? Obviously seems to be an issue if you toasted a clutch @ 19,000.... Lol
Also, did you go through the break in process?
2005Redfire6 is offline
Old 04-23-2013, 04:14 PM
05slpGT
05slpGT's Avatar
damn, 19k! Im at 94k on my stock one and have done plenty of burnouts and been to the drag strip. Like Redfire said, did you break it in? How many miles do you have on the new clutch?
05slpGT is offline
Old 04-24-2013, 09:36 AM
nick2010gt
nick2010gt's Avatar
I've got 44k on this new clutch
Old 04-24-2013, 10:22 AM
nick2010gt
nick2010gt's Avatar
i guess i broke it in, i bought the car with 9 miles on it and put 5000 on it before i started driving it hard and yes it was my first 5 speed car and that was my first burnout... i learned the hard way.
Old 04-24-2013, 11:15 AM
2005Redfire6
When you say problems it just won't go into gear?
Old 04-24-2013, 12:45 PM
danzcool
danzcool's Avatar
Originally Posted by nick2010gt
...have been having problems hitting 2nd and 3rd in real high rmps with the traction control off. any suggestions??
Sounds more like a transmission or shifter issue than a clutch issue. Synchros may be bad, or you may just need a good aftermarket shifter.
danzcool is offline
Old 04-24-2013, 05:37 PM
nick2010gt
nick2010gt's Avatar
it wont go into gear while racing, daily driving its fine. it will go into gear if it is forced or you give it 2 seconds. I checked the trans fluid and its fine. so my next thought would be maybe the slave cylinder maybe needed to be upgraded or the synchros maybe needing replaced. but I have heard that in some of the newer cars that the shifter is mounted in the console instead of the being mounted to the trans so it can have problems lining up to go in gear so the hurst shifter would clear it up.... but I figured I would ask on a forum and see if anyone out there has had this happen to heard of this and could give me advise on what I need to do to get this fixed....
Old 04-24-2013, 06:50 PM
2005Redfire6
It could be due to the stock shifter, I know the stock shifter was a pain in the *** to get into gear sometimes. And yes because its a remote mounted shifter.
Old 04-24-2013, 07:47 PM
nick2010gt
nick2010gt's Avatar
that's what I needed to hear, because im trying to find people who had the same problem. I guess I will go out and buy a new one and post later the results. thanks for the info
Quick Reply: stage 3 clutch, misss 2nd and 3rd
