Sponsored by:
Sponsored by:
Old 10-22-2015, 06:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Electric power seat not working
Old 05-03-2013, 06:35 PM
RandomHero82
RandomHero82's Avatar
Mine has the problem every so often where it just doesnt work. Try again later and its fine.... Irritating at best.
RandomHero82 is offline
Old 05-03-2013, 06:50 PM
edwin108
edwin108's Avatar
Check the large plug/harness under the seat, it may not be connected securely. Don't unplug the yellow one if your car has one, that's for the side airbag.
edwin108 is offline
Old 05-03-2013, 10:19 PM
AzPete
AzPete's Avatar
Forgot about the perfect world...lol
As for the intermittent issue...could be a dirty switch also. Try some contact cleaner in the switch and operate it at the same time.
AzPete is offline
Old 05-04-2013, 05:46 PM
JayBeStangs94
JayBeStangs94's Avatar
Found the fuse. It's blown. I'll get a new one from my brothers shop. How do i go about removing the fuse?
thanks guys
JayBeStangs94 is offline
Old 05-04-2013, 06:06 PM
edwin108
edwin108's Avatar
thanks guys
You should have a fuse puller in the passenger compartment fuse box:
edwin108 is offline
Old 05-04-2013, 06:25 PM
JayBeStangs94
Well thats definately good to know! Would be nice if cars came with every tool needed to take it apart and put it back together agian
Old 05-07-2013, 02:17 PM
JayBeStangs94
So i replaced the fuse and the seat was able to move back and forth! I was stoked. Then i attempted the lumbar support (which previously wasn't working) and i heard the motor attempt to move the lumbar support. It never moved, so i thought, cool; ive got a functional power seat at least. Then it stopped working. I went and checked the fuse and it was blown yet again! What is going on!?
Old 05-07-2013, 02:32 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Lumbar switch/motor is probably shorted or the motor is restricted to where it causes an overload.
Derf00 is offline
Old 05-07-2013, 02:48 PM
TheStigSC
TheStigSC's Avatar
This. If I were you, I wouldn't touch the lumbar support or you'll probably keep blowing it. And fixing it will be pricey as stated above unless through a junk yard or online somewhere possibly like rockauto.
Good luck.
TheStigSC is offline
Old 05-07-2013, 03:13 PM
JayBeStangs94
gotcha. Thanks guys
Quick Reply: Electric power seat not working
