Headlights and fogs on a gt
Alright, I have checked all the fuses, relays, and even the wiring harness behind the switch. Nothing still no lowbeams and fogs at the same time. The only thing I can think of is that either the switch is bad, or I have a bad ground. Does anybody know where the headlights ground in these cars?
White05gt, no, when I turn the switch to the symbol, with the "p" just the marker lights turn on. If the ignition is on, and I pull the switch out, the fogs turn on. If I turn it one more notch, I get the brights, and the fogs turn off. Which from what I understand is normal.
When the brights are on....does moving the turn signal switch towards front or back of the car change the headlights from high to low?
In the "p" position, you only get the marker lights and fog if switch pulled....that is normal. Almost sounds like you are not operating the high/low switch properly.
Seanam
10-04-2015 10:15 AM
