Small rust spots on roof - Page 2 - MustangForums.com
Old 05-15-2013, 03:24 PM   #11
POWERMAN_
POWERMAN_'s Avatar
Awesome.
Make sure to leave sufficient time between coats for the touch up paint.
Save the last coat for the clear coat touch up as it wont be as noticeable when you layer it up, and can be polished (even) out accordingly!
POWERMAN_ is offline   Reply With Quote
Old 05-15-2013, 11:09 PM   #12
mustangspotential
mustangspotential's Avatar
Quote:
Originally Posted by POWERMAN_ View Post
Awesome.
Will do. Do you know exactly where I can get the clearcoat? I don't have it, just the touch up. Got that off eBay. Should I just look for my color code in Ford clearcoat?
mustangspotential is offline   Reply With Quote
Old 05-16-2013, 12:29 AM   #13
JayBeStangs94
JayBeStangs94's Avatar
I had exactly the same issue. I sanded it down, wiped it over, and put touch up paint on it. Check on it later and consider another coat. good luck!
JayBeStangs94 is offline   Reply With Quote
Old 05-16-2013, 10:31 AM   #14
POWERMAN_
POWERMAN_'s Avatar
Quote:
Doubt the dealership carries clearcoat..but it's worth a try.
You could use Duplicolor's products.
I use the clearcoat touch up from Turtle wax's scratch repair kit.
Old 05-16-2013, 12:03 PM   #15
Roy_R
Roy_R's Avatar
Roy_R is offline   Reply With Quote
Old 05-16-2013, 10:24 PM   #16
mustangspotential
I think I'm going to use the clearcoat in the Turtle Wax Scratch Repair Kit, simply because it's available at Autozone near me instead of waiting for something to get shipped to me.
Stupid question incoming: So clearcoat is what exactly? Because if I put touch up paint on, and then the clearcoat that comes with this, it will match the color? I don't know much about it. Or do I need one that specifically is matched to my color?
Old 05-17-2013, 01:13 AM   #17
Roy_R
Roy_R's Avatar
I use a primer, followed by base coat...2-3 layers, then polish that smooth (use t-shirt wrapped around the edge of a credit card), clean that up, followed by clear coat...
Old 07-12-2013, 04:23 PM   #18
POWERMAN_
POWERMAN_'s Avatar
Just checkin in to see how this turned out..
Old 07-12-2013, 09:59 PM   #19
2cokeman
2cokeman's Avatar
Stone chips, brake dust fly out!
2cokeman is offline   Reply With Quote
Old 07-13-2013, 01:52 PM   #20
mustangspotential
Well I got rid of the small rust spots but I noticed that they can pretty much happen anywhere and you just have to be vigilant. I blotched the touch up paint a little though.
What is the tube coming out of the air intake that goes to the small box? daltron 5.0L GT S550 Tech 17 04-28-2016 09:10 PM
Original Owner 1970 Mustang b8checker Classic Mustangs (Tech) 8 10-08-2015 01:55 PM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 06:26 PM
GT500 front LCA question UrS4 S197 Handling Section 1 09-30-2015 11:13 AM
Original Owner 1970 Mustang b8checker New Member Area 3 09-30-2015 08:11 AM
