Sponsored by:
Sponsored by:
Engine Fail Safe Again?
Old 05-13-2013, 04:15 PM
Machbud
Machbud's Avatar
Default Engine Fail Safe Again?
I'm having an issue with my 05 GT going in to the " Engine Fail Safe Mode" when I
jump on it and run her hard? the car will only go about 5 Mph and when I shut
the Motor off and start it up again it will run OK? I put my Code reader on it and
it said it Passed with No Codes? How is this possible? there has to be a reason
why this happens. It sucks having to drive my car and Not have any fun. Does,
anybody have an idea what the problem may be? I only have minor after market
Hi-Perf parts BBK Throttle Body, C&L Intake W/ Tune, MSD Coils and BBK
under drive pulleys and all of these parts have been on for years with No issues
until recently.
Machbud is offline
Old 05-13-2013, 04:24 PM
ziperhead
ziperhead's Avatar
Best guess throttle body connections
ziperhead is offline
Old 05-13-2013, 04:55 PM
moosestang
moosestang's Avatar
Good chance it's the throttle body. Google bbk throttle body sucks and you'll see all the problems.
moosestang is offline
Old 05-13-2013, 06:31 PM
SpartaPerformance
SpartaPerformance's Avatar
I agree, have been a boat load of concerns with BBK unit. Chuck it. As for code reader it will only read current key cycle concerns if there is no check engine light on at the time of the reading it will pass. You need a full scanner to check such concerns with no CEL.
SpartaPerformance is offline
Old 05-13-2013, 10:42 PM
Lem-06
Lem-06's Avatar
check for any vacuum leaks in the intake.
my car did this exact thing when the previous owner had replaced it with a random hose that led to nothing
Lem-06 is offline
Old 05-14-2013, 06:17 AM
moosestang
moosestang's Avatar
for those that don't know, the bbk throttle bodies use brass gears and will cause binding eventually. Stock, gt500, frpp throttle bodies all use plastic gears.
Old 05-14-2013, 07:10 AM
TheStigSC
TheStigSC's Avatar
It's the TB. Toss the BBK and grab a FRPP or GT500 and retune. It's for the best
TheStigSC is offline
Old 05-14-2013, 07:32 AM
adidasUNT8
adidasUNT8's Avatar
+1 TB or TPMS sensor went out inside the TB
adidasUNT8 is offline
Old 05-15-2013, 02:23 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Scrap the BBK. Infact spending money on any upgraded TB (FRPP or other) with a fairly stock car is a waste of money.
If you have your old TB put it back on. Bet the problem goes away. If you don't have the old one, does your code reader have data logging capabilties? Data log while you drive and then review the data to see what the issue is.
Derf00 is offline
Nick Oliver
10-17-2018 04:22 AM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
v8sn95
09-07-2015 10:17 AM
Quick Reply: Engine Fail Safe Again?
