Squealing from Engine/Trans Connection
Hey guys. Just got done doing a procharger install on my 05 GT and now when I start the car it has a weird screech/squeal in a pattern at idle and 1500 rpm. The sound goes away if the rpm's change from either of those two points. It sounds like a high pitched turkey and has a weird patter of screech, screech, screeeech that repeats. When I turn the car off the sometimes the screech slows and is prolonged like it's slowing down but still grinding. It seems to be coming from the immediate area around the engine/tranny joining. I did nothing to this area of the car or to the drive train. The sound doesn't change whether the clutch is in or out and the sound persists even if the supercharger belt is removed. I've been searching and I think I narrowed it down to either the separator plate rubbing the flywheel (?) or somehow my pilot bearing magically stop working (?). Any suggestions are appreciate. If all else fails, I'll start looking for the turkey that is stuck in there
breaking
10-02-2015 01:27 PM
TfcCDR
09-14-2015 12:08 PM
