Sponsored by:
Sponsored by:
Old 10-22-2015, 03:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Exterior Guides
Print Wikipost
Opinions on first mods? 2014 GT
Old 06-10-2013, 08:34 AM
CMcNam
CMcNam's Avatar
Originally Posted by DocSnickers
When you lower the car your going to want to drive the car for about a month.
Then get the alignment and camber checked. Good chance your front and rear camber may be out of spec. In that case you would need a panhard bar for the rear tires and either camber bolts or camber caster plates. The plates are really only needed if you want to adjust the cars camber on the fly if not the camber bolts will do the same thing.
If you do end up needing to adjust camber which you most likely will. Look at the Whiteline panhard bar. Whiteline is a tad bit more spendy but its high quality stuff.
Panhard bar does NOT adjust camber. You have a solid rear axle. You can NOT adjust the camber on the rear of these cars (unless you're really determined and bend your axle tubes and put in a LOT of extra work) and lowering them will not affect rear camber, only the front. A panhard bar centers the body over the rear axle. An adjustable one allows you to recenter the body after lowering it pushes the axle to one side.
CMcNam is offline
jerrytubes
10-23-2015 12:11 PM
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
mdg
10-01-2015 07:04 AM
folivier
09-26-2015 02:28 PM
Quick Reply: Opinions on first mods? 2014 GT
