Advice for a newbie
Advice for a newbie
Hello to all! I'm a former "old school" Fox 5.0 guy and my wife and I are wanting to become "new school" and are considering buying a 2011-2013 5.0 Stang w/an automatic. So, with being new to the S197, I was wanting to know what are some bolt-on performance upgrades that are available? Underdrive pulleys?, aftermarket exhaust?, computer tuning?, K&N air filter?, etc. I'm want to keep the car a daily driver, but also do some bracket racing on the weekend. I'm not interested in increased HP numbers, just increased performance(i.e. lower E.T's). Any info will be much appreciated! God Bless!
Yes, exhaust, CAI, gears and a tuner... The gears and tuner will be best bag for the buck. Look into 3.73s or 4.10s, those are the most common for aftermarket.
Can i ask why not a manual?
suspension upgrades will be your friend. Lowering springs, shocks/struts, camber plates, panhard bar, LCAs, UCAs, etc....
Do you need to keep your warranty? My Mech wanted to weld my side differential tubes so they didn't twist under launch, I opted for an AM Swarr-bar to grip and hold them. I'm working on bomb proofing the drive-line. One piece alum shaft, better posi - Not Torsen that I'm told is a track (why it's in a Boss) not drag friendly posi. Maybe a Yukon or Detroit and If I'm doing a Stage 1 clutch (so it's still street-able D/D) might as well do an alum flywheel with a diff axil shaft up-grade. Relocation brackets (what use to be those yellow traction bars of the 70's) will give you traction but you may need a driveline specialty shop to fix the piņon angle of the driveshaft, or you'll have a wine.
You'll put down close to 360-370 with premium in a 2013/14 I added a custom tune, Boss intake and exhaust work, and I have 410 at the wheel. I've totally gutted and replaced all the suspension components and added little things like low expansion break-lines, bump steer, X-11 ball joints, steel braided clutch line and I'm only half way to finished. Also ditch that stock shifter. If you get a 2013/14 you'll see and feel what it's like to go from a 4.6 that has to go to the moon mod wise to match the stock 5.0 variable timed cams.
I like not worrying about Force induction S/C's and spray problems.
