Sponsored by:
Sponsored by:
Will 4.10's cause the 4.0's driveshaft to fail ealier?
Old 06-12-2013, 01:03 PM
SonicBlue08
SonicBlue08's Avatar
Originally Posted by Stang-aholic
Ive taken mine up to 120/130ish with 3.73s and it vibrates like crazy
Does a GT have the same problem? I was planning on 3.73's for my 08 and I will take it up to 140+ every now and then. Do the GT's have the same driveshaft as the V6?
SonicBlue08 is offline
Old 06-12-2013, 03:18 PM
crazyassracer
crazyassracer's Avatar
Upgraded my 7.5 to 3.73's and a trac-lok Spring of 2012. So far I have had two trips to the drag strip and 4 hours on track time at Gingerman Raceway without any problems. After upgrading the the gears I upgraded the lower control arms to combat wheel hop. Spring of 2013 I upgraded to an aluminum drive shaft. The drive shaft really smoothed out the vibration I was getting at freeway speeds.
crazyassracer is offline
Old 06-12-2013, 04:48 PM
pascal
S197 Section Modder-ator
pascal's Avatar
Nope, GT is 2 piece while the sixxer is one unit.
Also the pinion flanges are different on both these cars so the DS won't swap anyway.
pascal is offline
Old 06-12-2013, 10:25 PM
ctross
ctross's Avatar
Anyone know a formula to figure out driveshaft rpm's? Still trying to figure out just how much earlier (mph wise) I'd be entering the danger zone.
ctross is offline
Old 06-13-2013, 12:11 AM
VistaBlueFrank68
VistaBlueFrank68's Avatar
I modded a 4.0 once, 3.73 posi on the 7.5 was putting down good power would fry the tires - 17x235x55 street tires. Drag slicks broke your diff. 4.10's will run high rpm on the highway lower fuel milage but better around town. I'd do 8.8 with 3.73, works for the new 3.7's.
VistaBlueFrank68 is offline
Old 06-13-2013, 01:37 AM
AJ06GT
AJ06GT's Avatar
Edit: Okay, so I've had a few beers and wasn't really thinking straight. I'm revising my original post.
I'm starting to think an upgraded driveshaft may be worth it anyway. I'm not sure just how much gears would affect how fast it spins because I'm not that smart in car math, but I gather your drive shaft is as about clunky and heavy as a GT's and could use the upgrade anyway. I think you'd be alright if you did add gears, I'd still be more worried about the diff itself as others said, especially if you're hooking up well. Just try not to get on it too much until you're sure it can handle it.
AJ06GT is offline
Old 06-13-2013, 11:19 AM
cariacou
cariacou's Avatar
Originally Posted by ctross
So, I finally made up my mind to go with 4.10's (took long enough) and was about to place the order when a suggested product in the sidebar caught my eye and made me think.
This might be a total newb question, but better safe than sorry, right?
A higher gear ratio is going to make my drive shaft spin more per tire rotation correct? So, does that mean the drive shaft will fail at an earlier speed than the 130-140 range its already known to buckle at because it'll be spinning faster earlier?
I dont plan on removing the governor with the tune after install, but I occasionly like to take the car up to about 110 when im the only one on the freeway.
Does anyone have experience with 4.10's in their 4.0 at high speeds? Should I wait till I can get an alumimnum driveshat?
doesn't the 2005+ have 8.8 factory ?
I can't talk for the 2006 , but I have a 2011 v6 and went to 4.1 a month ago. 100 is safe. I have been to 110 a few times, but I feel like the car is working rather hard to reach this. so I usually stop around 105.
I have the stock DS
cariacou is offline
Old 06-13-2013, 11:20 AM
cariacou
cariacou's Avatar
Originally Posted by AJ06GT
2006 Mustang GT
2008 BMW E92 335i - GONE!
2003 Mustang Cobra - GONE!
1997 Mustang GT - GONE!
... why
cariacou is offline
Old 06-13-2013, 12:33 PM
ctross
ctross's Avatar
I have the stock DS
The 2005-2009 or 10? V6's got 7.5 rear ends. I'm def. going to end up getting an 8.8 with my gears now because its not much more and that seems to be everyone's biggest concern. I didn't know gears added that much more power? the newer models (10/11 and up) have a different DS, they are now 6 speed standards aren't they? So I assume the entire drivetrain has changed.
ctross is offline
Old 06-13-2013, 12:57 PM
AJ06GT
AJ06GT's Avatar
... why
Why are they gone? I sold the Mustangs for the BMW, then I lost my job and it had to go. I know, I should have kept the Cobra.
AJ06GT is offline
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
Matt's 95 Stang
10-05-2015 07:16 AM
junior04
09-28-2015 10:53 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Will 4.10's cause the 4.0's driveshaft to fail ealier?
