Road noise!
Road noise!
About 500 miles ago my 13 GT/CS started having a mild sound coming from the car. The sound is best described as "road noise", when the tire rolls over the road a humming is heard. The sound gets a little louder when I brake. My wife can hardly hear it on the passenger side but when she hears out of the drivers window it is clearly heard there! Is this the tire or possibly a wheel bearing? The car has app 20000 miles, I dont know if the tires are covered by warranty. (Im no where near my car today so I cant look at the paperwork)
I would bet on tires. Does the noise tone or level change when the paved road surface changes. What about a slight change of direction....does that change the sound? Rotate the tires from side to side and see if the noise moves.
gears ? drive the car, put in neutral, if sound goes away that's it
check the tire lug nuts ? maybe one isn't screwed in well. pop the trunk, you should have the wrench in the spare tire compartment.
did you check the tire pressure ? it could come from here too
how does the brake pedal feel ? is it firm or soft ? I wonder if it could come from a brake pad rubbing
KingRando
10-02-2015 08:06 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
mungodrums
Suspension
09-24-2015 10:12 PM
