Sponsored by:
Sponsored by:
Road noise!
Old 06-17-2013, 07:41 AM
Mayberry40
Mayberry40's Avatar
Default Road noise!
About 500 miles ago my 13 GT/CS started having a mild sound coming from the car. The sound is best described as "road noise", when the tire rolls over the road a humming is heard. The sound gets a little louder when I brake. My wife can hardly hear it on the passenger side but when she hears out of the drivers window it is clearly heard there! Is this the tire or possibly a wheel bearing? The car has app 20000 miles, I dont know if the tires are covered by warranty. (Im no where near my car today so I cant look at the paperwork)
Mayberry40 is offline
Old 06-17-2013, 08:04 AM
bones302
bones302's Avatar
coming from front or back of the car?
bones302 is offline
Old 06-17-2013, 08:16 AM
gabb
gabb's Avatar
If its coming from 1 side it is most likely a bearing. If its from the whole car I would say tires.
gabb is offline
Old 06-17-2013, 08:30 AM
Mayberry40
Mayberry40's Avatar
I cant tell if its the front or back I just know its louder on the driver side
Old 06-17-2013, 09:53 AM
AzPete
AzPete's Avatar
I would bet on tires. Does the noise tone or level change when the paved road surface changes. What about a slight change of direction....does that change the sound? Rotate the tires from side to side and see if the noise moves.
AzPete is offline
Old 06-17-2013, 10:16 AM
bakerjd
bakerjd's Avatar
I'll tell you now...tires are not covered by a warranty.
bakerjd is offline
Old 06-17-2013, 10:31 AM
Weather Man
Weather Man's Avatar
Probably have a little cupping on the tires. Alignment is out of whack a little.
Weather Man is offline
Old 06-20-2013, 07:29 PM
Mayberry40
Mayberry40's Avatar
From what I read in the warranty the tires are prorated.......IF that is the problem.
Old 06-21-2013, 02:43 AM
cariacou
cariacou's Avatar
gears ? drive the car, put in neutral, if sound goes away that's it
check the tire lug nuts ? maybe one isn't screwed in well. pop the trunk, you should have the wrench in the spare tire compartment.
did you check the tire pressure ? it could come from here too
how does the brake pedal feel ? is it firm or soft ? I wonder if it could come from a brake pad rubbing
cariacou is offline
Old 06-21-2013, 03:42 AM
Lem-06
Lem-06's Avatar
if there is a defect in the tire it would probably be covered.
but after 20k miles it simply being worn down they wouldnt cover
Lem-06 is offline
KingRando
10-02-2015 08:06 AM
folivier
10-02-2015 05:34 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: Road noise!
