Sponsored by:
Sponsored by:
18" wheel and tire combinations
Old 06-24-2013, 09:32 AM
aspblackstang05
aspblackstang05's Avatar
Default 18" wheel and tire combinations
im sure many of you have dealt with threads like this before, but im going to ask anyway. i have a 2005 mustang gt that is currently sitting on 20's which im not particularly fond of. id like to move towards a more classic muscle car look and drop down to 18's, the only problem is im not sure what to run for tires on the front. i plan on buying a staggered set of black bullet wheels in 18x9 and 18x10 with 295 45r 18's on the back. i thought about 255 45r 18's for the front but i think its a little too much sidewall, and 255 35r 18's might not have enough. maybe some of you running a similar setup could post some pictures to give me a better idea of what i want to do?
are 295 45r 18's the biggest tire i can fit in the rear? i like how tall the 295 45r 18's are but wasnt sure if i could go up to 305's without rubbing.
the car is not lowered, but i have plans to do so in the future.
thank you for any help,
ryan
aspblackstang05 is offline
Old 06-24-2013, 10:25 AM
05 Mustang
05 Mustang's Avatar
255/45/18's up front and 285/40/18's (or 295/40/18's) out back will keep the overall diameter same as stock. These are the sizes I'd look at.
05 Mustang is offline
Old 06-24-2013, 10:38 AM
Nuke
Nuke's Avatar
Max tire width depends on the wheel width. I know that my 9.5" wide 18's will take 285 as the recommended max.
As 05mustang suggested, 255's front and 285's rear are a superb combo. I wouldn't go wider than 255's up front due to tramlining. My 275's all around are horrid for tramlining due to those 275's up front..
Not only am I, also, not a fan of 20's, but when my '07 with it's 18" wheels sits next to my wife's '06 with 17" wheels, I wish that I had gone 17's. The tallest sidewall that I can run without increasing the tire O.D. too much is a 45 and that's just too skinny a sidewall to match the retro look that these S197's were based upon.
Nuke is offline
Old 06-24-2013, 02:00 PM
mayo
mayo's Avatar
A couple of pics you might find helpful.
My setup...
18x9 255/45/18
18x10 295/45/18
First pic is pre-drop on a stock suspension.
The second, after a 1" all around drop using frpp p springs.
Personally I don't think you would want to go smaller up front with the 255/35/18 as there is already an 1.5 inch difference between the 255/45 and the 295/45. To answer you other question, yea you can go bigger than the 295/45. Even with the 1 inch drop, I had room to spare on the rear and have seen guys stuff a 305/45/18 on the rear with stock suspension and no rubbing problems...hope this helps.
mayo is offline
Old 06-24-2013, 02:15 PM
cariacou
cariacou's Avatar
take 18x11 on the back and run 315s
cariacou is offline
Old 06-24-2013, 06:36 PM
aspblackstang05
thank you for all your help. i wasnt too sure on the 255 45 up front, but it looks perfect! i think im going to stick with the 295 45 in the rear. its mainly a dd and i dont think 305's for the street.
thanks again,
ryan
Old 09-05-2013, 02:27 AM
Mattr89
Mattr89's Avatar
My setup...
18x9 255/45/18
18x10 295/45/18
I currently have my car lowered with H&R supersports 1.9 rear drop. which is .9 inch more than you. Do you think you had enough room to spare to go .9 lower on your drop?
The reason I ask Is i want to do 295/45/18 Nitto NT05 tires. I have 18x9's and I am positive that 295 will be ok as I have 285 right now and nittos run narrower anyway. I have very little if any bulge, and there is a SVT guy running around with 315's on a 17x9 with no issues so i figured that 295 would be easy.
Any thoughts?
Mattr89 is offline
Old 09-07-2013, 08:35 PM
robs
robs's Avatar
Originally Posted by Nuke
<snip> I wouldn't go wider than 255's up front due to tramlining. My 275's all around are horrid for tramlining due to those 275's up front..
I had to google tramlining... I've always called this "slot car-ing"... My 255's do it bad.. the more worn they become, the worse they are at it..
robs is offline
Old 09-07-2013, 11:57 PM
808muscle
808muscle's Avatar
Originally Posted by 05 Mustang
255/45/18's up front and 285/40/18's .
This is what I'm running and I wouldnt change a thing.
Attached Thumbnails 18&quot; wheel and tire combinations-img_20130511_152520_522-1-.jpg
808muscle is offline
Old 09-09-2013, 07:53 AM
Norm Peterson
Norm Peterson's Avatar
Whatever you call it, some tire makes/models do this much worse than others, and with some it's not noticeable at all.
If you're lowered but not by enough to have bothered with re-aligning it, you may also have a little toe-out, which is inherently somewhat "twitchy". A double dose of twitchy will keep you busy . . .
Norm
Norm Peterson is offline
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
10-07-2015 07:02 PM
09-16-2015 07:53 PM
09-08-2015 11:50 AM
Quick Reply: 18" wheel and tire combinations
