reaching 120 mph slower? with 4:10 - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 07-16-2013, 05:33 PM   #11
YoungBlood
YoungBlood's Avatar
How do you feel about them besides over 120?
YoungBlood is offline   Reply With Quote
Old 07-16-2013, 05:38 PM   #12
CPTCO
I got mine about the same time as the OP. I feel like my car is pulling harder past 120. It also seems like my power is more available in ALL gears. Many people will say they aren't the best for highway miles. But I just drove my car on a 900 mile road trip. Loved every minute. Passing cars easily in 5th, plus great launches.
CPTCO is offline   Reply With Quote
Old 07-16-2013, 11:28 PM   #13
Ricardo
Ricardo's Avatar
Over 120? My car came with 3.31 and now with 4.10 has a higher top speed. People are misled into thinking 4.10s make you lose top speed but it's around here somewhere that the hp you need to top out that gear is pretty dang high. My car cannot hit redline in 5th with 4.10s so I doubt you will.
edit: some searching points to 180ish but thats a speed nobody here should ever go without an ambulance standing by
Ricardo is offline   Reply With Quote
Old 07-17-2013, 08:42 PM   #14
FlamingoGT
Quote:
Theoretical top speeds are slower with 4.10s than with 3.31s (or any other gear ratio numerically lower than 4.10). But where reality beats theory is that, as noted, these cars don't have the oomph to reach that theoretical top speed.
Where the 4.10s really shine is in the low end pull getting you up to speed sooner as well as allowing you more use of the power band.
FlamingoGT is offline   Reply With Quote
Old 08-03-2013, 05:12 PM   #15
outceltj
outceltj's Avatar
So my take on whether your slower with 410s could be true. I have had this talk with some friends and our conclusion was that you basically need more hp to get to it quicker. As was stated earlier there is s reason why people run 410s at the track. When ur car hits fourth you just need more power to keep her picking up speed
outceltj is offline   Reply With Quote
Old 08-03-2013, 06:46 PM   #16
tbear853
tbear853's Avatar
Quote:
Originally Posted by mustang_gt808 View Post
ok guys before i installed my 4:10s from 0-120 it seemed faster with my 3;55 gears? yesterday i opened it up from 0-120mph now with my 4:10 gears and it seamed when im passing 90 or 100mph it been slower reaching 120? i might be wrong but can anyone confirm this please. thanks guys
At 80-100 mph now likely you are in 4th instead of 3rd, and overall gearing is some higher than 3rd with 3.55s. .... but likely you are getting the first 60 feet quicker which is important in 1/4 mile runs. Overall, the 4.10s will increase torque multiplication through out the speed range as long as you keep her in the right transmission gear to keep the engine up in the power band .... to maximize torque multiplication .... and thus the engine will accelerate the car harder, reaching higher speeds in less time, and will likely run faster in 5th on top if pushing any air.
I recall in 1979 we had Chrysler Newports with 360 engines and 3.23 rear gears, then in 1980 we got Plymouth Gran Fury s with exact same engine in same body with same trim, but 2.94 rear gears. The '79s were faster accelerating and would run a good 5-7 mph faster on top because the '80s hit that wall of not making enough RPM when resistance reached a certain level about 120 .... where the '79s would push 125-127 .... but engine turned faster .... and the '80s got slightly better gas mileage.
tbear853 is offline   Reply With Quote
Old 08-03-2013, 06:50 PM   #17
Stang-aholic
Stang-aholic's Avatar
higher gears (4.10s) = faster acceleration, lower acceleration over 60 mph.
lower gears (3.31s) = normal acceleration off the line, linear acceleration over 60.
The reason: 4.10s pull harder off the line because they keep your engine in the main power range (3k to 6k) more of the time. But at speeds above 60/70 your engine will be running much higher RPMs, but doing more work because the torque require to make the car go faster at that speed is greater with 4.10s vs 3.31s. Therefore your car is faster than stock 3.31s (stock) from 0-60/70mph, but slower from 70-120+
Stang-aholic is offline   Reply With Quote
Old 08-04-2013, 01:05 AM   #18
drewsky
My car never felt slower after 60mph after the 4:10 install. It felt like it pulled a little harder all the way through. Where are you getting this? Is there a math to this, I'm curious now
drewsky is offline   Reply With Quote
Old 08-04-2013, 04:26 AM   #19
AK_Kayaker
AK_Kayaker's Avatar
Quote:
I would agree with you, as the increased torque multiplication is going to give better acceleration across the entire speed range.
I think maybe this is some kind of Keynesian math, and I think we all know how good that stuff works.
Maybe with luck Norm will step in and set things straight, till then.
AK_Kayaker is offline   Reply With Quote
Old 08-04-2013, 10:58 AM   #20
Norm Peterson
Norm Peterson's Avatar
For a few mph immediately following the speed at which you upshift the 4.10-ratio car, the 3.55-geared car will have slightly stronger acceleration. This is because the 4.10-geared car loses more due to the taller overall gearing than it gains by dropping back to around the torque peak rpm. I haven't ever tried to determine what this might amount to or if it'd be enough to clearly notice.
Take the speed limiter away and I think I found that the 4.10's actually pull an extra mph or two on the top end (there's a fairly fussy mathematical simulation for determining real-world top speed). Basically, 4.10's put the engine closer to peak HP rpm in 5th at the high 140-ish/150 range than you would be with 3.55's. With 3.55's and a stockish 4.6L, you don't have enough power at enough revs to pull ~150 in 4th with stock tire sizes.
Norm
Norm Peterson is offline   Reply With Quote
Kenny Brown AGS 4.0 panhard bar relocation flash_xx S197 Handling Section 14 10-16-2015 08:23 AM
TNT, New PB TCStangerv6 Street/Strip 12 10-11-2015 06:57 PM
extnesion for radio antenna to head unit kevsgt 2005-2014 Mustangs 5 10-09-2015 11:12 PM
Racer Appreciation Party at the NMRA World Finals nmra1965 Other Professional Racing 0 09-26-2015 11:46 AM
Pinion angle, poly bushings, 1 piece DS mtgldr S197 Handling Section 1 09-10-2015 10:43 PM
