Sponsored by:
Sponsored by:
Wierd instrument lights, help! :D
Old 07-19-2013, 12:06 AM
White05GT
White05GT's Avatar
How old is your battery? Mustangs are notorious for acting like they are demon possessed when the battery gets ready to drop dead.
Anyplace that sells batteries can check it free for you. Let us know what the issue turns out to be.
Might want to get the alternator tested at the same time also.
White05GT is offline
Old 07-19-2013, 06:43 AM
Nuke
Nuke's Avatar
Baffling. If the charging system and SJB are ruled out, I think I'd start troubleshooting by having something in the car tied into the rear light circuit (buzzer, lamp) so I could have indication of when the lights erroneously came on and to see if there was any action on my part that would prompt them such as clutch pedal motion, shifter motion, etc.. I suppose I'd be looking for an intermittent short circuit.
Nuke is offline
Old 07-19-2013, 10:09 AM
Mr.Ski
Mr.Ski's Avatar
Take it to someone (probably dealer) that can pull codes for the ABS system. The PCM and ABS and RCM (restraint control module) work toegether for your traction control. Without pulling codes you are just hunting in the dark. You most likely have an intermittent sensor fault.
Mr.Ski is offline
Old 07-20-2013, 10:58 AM
SteveDwsn
SteveDwsn's Avatar
I agree with White05GT, check the battery. Check the voltage regulator too. Sorry you are having electrical issues, but at least I know mine isn't the only one with an annoying gremlin.
SteveDwsn is offline
Old 10-14-2013, 11:46 AM
GTgirlCA
GTgirlCA's Avatar
Thanks for the link, Nuke. Great to have on hand.
GTgirlCA is offline
Old 10-14-2013, 01:26 PM
Nuke
Nuke's Avatar
Me or the link?
NP. We're all here to help one another.
Nuke is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Wierd instrument lights, help! :D
