Changed fluid in my TR3650! So much better..
I see that alot of people are using Mobil 1 ATF or Amsoil or Syncrhomesh..
I went with Castrol TransMax Mercon V. I also used 3.2 quarts, and the dude seemed confused because his computer said 4. Just put the 3.2 in there, lol.
The 1-2 ans 2-3 shifts require alot less effort and feels noticably better. I can bang the gears now at 6500 without getting locked out sometimes.
If you haven't changed out your fluid, do it.
The old fluid was almost black, which I don't know how to interperet. Is that normal for 65K?
We bought ours June, it's a 2008 GT 5 speed and has 22K miles on it and after installing a Hurst Billet shifter .... maybe a week later .... I changed the factory lube for Mobil 1 Synthetic ATF.
Largely for piece of mind (I'm not likely to try full throttle power shifts like the ones I used to do with my old Chrysler or Muncie 4spd as these transmissions in these late Mustangs don't feel like they invite it like the old school 4 speeds with Hurst C+ shifters? So I'm more like "pausing 0.43 sec in neutral and then moving to next gear") .... it shifts at least as well as it did, maybe even some smoother or less notchy.
I changed mine at 80k, and went with Mercon V. It made a big difference in shifting and is smooth at 90*F and at -10*F. I know that others like aftermarket lubes, but I decided to just use the factory fill again.
stangin1996gt
09-21-2015 11:01 AM
LivingInThePast
09-16-2015 12:20 PM
