Need Help/Ideas: No lights instrument panel (Gauge Clusters)
2006 Roush S3
The car was purchased used.
Miles: 46K
Problem: No back lit speedo/tach/fuel/etc.
Items Checked:
*I checked the fuses and all seems well. I went by the book and then when I didn't find any blown I checked them all while I was there.
*Ruled out dimmer because it does dim the odometer/trip/radio and does turn on over head lamp
I was hoping is was just a burnt bulb but from what I am reading online these are LED lit? If that's true there is a bigger issue I believe, LEDs don't burn out very often. Especially when I bought the car with 45K on it.
I am looking for some ideas of what to check next or if someone knows what the smoking gun is.
Thanks guys
Miles: 46K
Items Checked:
Thanks guys
Did they ever work sense you bought the car? Does it have a warranty? I can tell you from the numerous times I took the cluster out of my 95 its not a fun job. Having small hands is almost a must.
As for whats wrong - would be a loose ground wire? I do not believe one bulb out should kill the whole cluster.
Hope someone else has some ideas.
Matthew
Matthew
