Sponsored by:
Sponsored by:
Has anyone here installed Roush Wheel Hop reduction kit?
Old 08-16-2013, 09:57 AM
2cokeman
2cokeman's Avatar
I have the Steeda kit, wheel hop gone bye bye!
2cokeman is offline
Old 08-16-2013, 10:24 AM
Andy13186
Andy13186's Avatar
springs and koni sports eliminated my wheel hop entirely
Andy13186 is offline
Old 08-16-2013, 08:28 PM
bigstick
bigstick's Avatar
Originally Posted by MWG2
Where exactly does it get installed? I went on You Tube trying to find a video on installing it...didn't find one. (I'm also getting the Roush control arms.) But I have no idea where the Wheel Hop Reduction is installed. Thanks!
It's merely an upper control arm. Had one installed at the same time that I put on a Roush stage 3 suspension on my '06. It worked as advertised and totally eliminated the wheel hop even without the LCA's.
The downside? As someone else already posted, it isn't adjustable. When I switched to BMR lowering springs with D-specs (which are better for drag racing), I had to switch it out to correct my pinion angle.
bigstick is offline
Old 08-16-2013, 08:36 PM
VistaBlueFrank68
VistaBlueFrank68's Avatar
Why do you all talk about LCA's as if they were an option to stop wheel hop?
Between the two LCA and UCA (2xUCA for older cars) they are what holds the
axil on.
Without them it would be a funny looking ride until your rear came off, then it
would be a F***ing hilarious looking ride.
Stronger LCA's and added LCB's will control wheel-hop and also a Swarr-bar. I'm getting one soon will eval for all later.
Notice the silver things LCB's on both sides. That tube bolted to the bottom of the LCB is the LCA. This angles the LCA down creating a stronger triangle = less wheel-hop.
Last edited by VistaBlueFrank68; 08-16-2013 at 08:43 PM. Reason: See the LCB's, love the LCB's
VistaBlueFrank68 is offline
Old 08-16-2013, 09:13 PM
wcgman
wcgman's Avatar
axil on.
I'm only speaking for myself, but I didnt mean for it to sound like it was optional. Only that a stronger LCA is important towards eliminating wheel hop because the stock LCA's and bushings are designed probably more for comfort and not performance, likely leading to wheel hop when pushed beyond it's limits.
So when you are saying LCB, you're referring to lower control arm bracket (relocation) specifically? I've done LCA's on 2 of my 06 and 10 and just bolted to the stock location. Im sure it's probably recommended, but unless the UCA is swapped out for aftermarket, is there a significant improvement with using relocation brackets too?
wcgman is offline
Old 08-18-2013, 09:48 AM
bigstick
bigstick's Avatar
So, let me qualify my answer so you don't feel the need to take it to extremes.
For all but hardcore racers, and depending on hp/tq levels and how sticky your tire is...upgraded LCA's are not necessary to stop wheel hop. An upgraded UCA is enough.
bigstick is offline
Old 08-18-2013, 11:42 PM
Jas5
Jas5's Avatar
Are you talking about wheel hop on flat pavement when accelerating?
Or wheel hop from going over bumps with the solid-rear-axle? Cause I never have had wheel hop on flat surfaces, only when going over bumps .... I feel like tire compound and width is another factor with wheel hop. I rode in a friend's 3000GT, FWD, and he has insane wheel hop.
Jas5 is offline
Old 08-20-2013, 08:50 AM
MWG2
MWG2's Avatar
Wheel Hop when I go around a turn and hit a small bump. Going to start with Roush LCAs and see if that helps. Having them installed the same time the 3.73 gear is installed along with a full TUNE.
BTW Jas5...NICE CAR!
MWG2 is offline
Old 08-20-2013, 05:55 PM
Jas5
Jas5's Avatar
thanks. as far as appearance i'd like to get a front chin spoiler but mine is already so front-heavy with the large hood.. dont wanna be driving a damn train with a cow thing
yeah dat solid rear axle.. after almost 2 years of ownership, i've definitely learned to let off the gas, even for .5 seconds, when I'm about to go over a bump or crack. It's scary as hell to be putting rubber into the pavement and hit a bump, feels like the drivetrain is about to snap
Jas5 is offline
Old 09-27-2013, 06:02 PM
MWG2
MWG2's Avatar
Smile Wheel Hop Update
Installed Roush LCA and it fixed the wheel hop problem...
AND...
Changed out the stock 2.73 gear with the Ford Racing 3.73...
Completed 3.73...(Note that the axle is now BLACK)...
SO...
With the Front Strut brace & CAI...
coupled with the 3.73 gear, and LCAs, and a BAMA TUNE, this Mustang is a sweet ride! Really fun to drive!
Oh yeah...SWEET RIDE!
MWG2 is offline
drfister
05-03-2018 10:38 PM
Urambo Tauro
12-17-2016 03:30 PM
Granatelli Sales
12-18-2015 06:22 PM
Soldier GT
09-08-2015 01:28 AM
08-18-2015 03:39 PM
Quick Reply: Has anyone here installed Roush Wheel Hop reduction kit?
