Sponsored by:
Sponsored by:
A/F gauge not working (autometer)
Old 08-20-2013, 06:05 PM
Jas5
Jas5's Avatar
Default A/F gauge not working (autometer)
I've searched online and some say it's from mis-wiring, or bad o2 sensor...
I have autometer gauges.
Ever since I got my car that came with blower and guages hooked up, the A/F will read on the very highest stoic (rich) reading, and at night when my headlights are on, sometimes I see the meter go from lean to stoic as if it's glitching. I say glitching because it bounces left to right sort of like how some newer car's RPM reading will redline then bounce back to idle when starting for a cool effect.
Gauge runs from 8 to 4 o clock and is stuck on 4 o clock
Anyone had this happen before? I'm wondering if my guage is dead.
Jas5 is offline
Old 08-20-2013, 06:31 PM
tbar
tbar's Avatar
If its full rich usually means the o2 sensor is bad.
tbar is offline
Old 08-20-2013, 07:03 PM
obxdude018
obxdude018's Avatar
Do you have a scanner/tuner to see the voltages that you're O2's are putting out. That will at least tell you if they are functioning correctly, I had an O2 pop the other day and it was reading 1.25 volts when the O2's should be only reading between .1 and .9 volts.
obxdude018 is offline
Old 08-20-2013, 09:17 PM
Jas5
Jas5's Avatar
Thanks guys.
No scanner or tuner but I guess I could try autozone/Oreilleys and get a free scan... but wonder if it's still free without a check engine light. I'll call them up tomorrow
Being supercharged I really need to address this guage or o2 issue
Jas5 is offline
Old 08-20-2013, 10:12 PM
808muscle
808muscle's Avatar
Originally Posted by Jas5
Thanks guys.
Just dont get in a race with the Farm Truck till its fixed! LOL
There is a video on youtube that shows you how to check your sensors with a can of brake cleaner.
808muscle is offline
Old 08-21-2013, 07:43 AM
obxdude018
obxdude018's Avatar
Brake cleaner, tb/carb cleaner, spray a little in a vacuum line, with the tuner/obd2 hooked up and watch the 02 voltage if it spikes to .99 then you know the sensor is operating correctly.
Tivo304
08-28-2023 12:19 PM
Mobiusone stang
09-07-2015 08:46 PM
TimeLord101
09-04-2015 09:27 AM
raleigh05GTO
09-04-2015 07:09 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: A/F gauge not working (autometer)
