Sponsored by:
Sponsored by:
Fuel pump won't turn on?
Old 08-24-2013, 11:47 PM
cema93
cema93's Avatar
Default Fuel pump won't turn on?
So there is a problem I have been having for the last few weeks that has become more and more common. I try and start my car and it cranks and cranks but won't turn over. We replaced fuel pump. We checked some fuses and relays. No helpful codes. It's not the PATS. There's plenty of voltage at the fuel pump plug in. gonna tow it to dealership Monday. Talked to a tech and he thinks it some computer electrical problem. the fuel pump does nothing when I turn the key. No sound no moving no whing. Almost as if it's not plugged in. Which it is
Any suggestions?
cema93 is offline
Old 08-25-2013, 06:58 AM
jpplaw
jpplaw's Avatar
Did you check the FPDM in the trunk?
jpplaw is offline
Old 08-25-2013, 11:24 AM
mattstang2007
mattstang2007's Avatar
Bad fuse possibly.
mattstang2007 is offline
Old 08-25-2013, 10:01 PM
cema93
cema93's Avatar
I haven't checked the fpdm. Whats it do? Can we put some jumper wires on it and bypass it?
cema93 is offline
Old 08-27-2013, 08:12 PM
cema93
cema93's Avatar
Found the problem. A ground wire was messed up inside the fpdm
cema93 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
Jose Corretjer
09-08-2015 06:32 AM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Fuel pump won't turn on?
