Sponsored by:
Sponsored by:
Chains for tires in winter
Old 09-06-2013, 05:07 PM
Lifter583
Lifter583's Avatar
Originally Posted by Nuke
If you need chains on your Stang to get anywhere, then you have NO business being on the road with a performance vehicle that you cherish.
PERFECTLY STATED!
Lifter583 is offline
Old 09-06-2013, 09:13 PM
Goldenpony
Goldenpony's Avatar
Do yourself a favor. If you're going to get winter tires, get them on all four wheels. The car will be much safer to drive. Also, Michelin XIce (I think that's the name) are a little better than the Blizzaks.
Goldenpony is offline
Old 09-09-2013, 07:08 AM
wcgman
wcgman's Avatar
OP - you don't use tire chains on a car. You want to look for tire cables. A little bit harder to find but they do exist. As far as winter tires, I switched to Blizzaks and have never looked back.
wcgman is offline
Old 09-11-2013, 08:30 PM
Margarita Girl
Is the tide gonna reach my chair?
Margarita Girl's Avatar
I don't drive the stang in the winter, but even in my Subaru, l try to keep the tank full if snow is in the forecast. Every bit of weight helps.
Margarita Girl is offline
Old 09-11-2013, 08:57 PM
tbear853
tbear853's Avatar
I agree with others, if studded ties are available, get a set on separate wheels and slip on when snow is anticipated.
Used to use much larger chains with V-bar reinforcement, but later my old job went with Class S chains, and toyed with the cables. The class S worked much better than cables, and I ran this set for 2-1/2 days in the big eastern snow of Dec 19-22, 2009 .... in three days I worked 46 hours and drove these for several hundred miles and still have them for emergency use if needed.
The cable chains I've used never lasted a full shift and the old V-bar reinforced chains held on so well that the chain would roll of spun and twist a side link loose and then you had a long chain with a hooked end flying around ..... seen some continue to drive and do thousands in damage, even ripping door handles off.
Go easy, don't spin them and keep speeds down, and when roads start getting just wet or dry, get them off fast.[/FONT]
tbear853 is offline
Old 09-11-2013, 09:27 PM
miner999r
miner999r's Avatar
canadian winter police chase video
miner999r is offline
Old 09-12-2013, 08:18 AM
GTjoe49
GTjoe49's Avatar
^^^LOL!
GTjoe49 is offline
Old 09-13-2013, 04:09 PM
tbear853
tbear853's Avatar
http://www.youtube.com/watch?v=QsxV49pmnL8"
LOL .....
tbear853 is offline
Old 09-13-2013, 09:33 PM
JThor
JThor's Avatar
Originally Posted by panther15
Has anyone ever used tire chains on their Mustang in the winter? If so, do they work well and did you ever have any problems like the chains breaking?
Like some of the others here, I have a separate set of snow tires - Blizzaks. 225's on 17" rims. I have driven it over Eisenhower pass in whiteout conditions, and it had plenty of traction. I would never consider chains with my setup.
However, I assume the winters in Iowa are a lot milder than Colorado. A separate set may not make sense if you only have to use them a couple of times a year.
My experience with chains/cables is that you can't drive very fast on them 25-30 mph max. Any faster and the tires tend to throw the chains.
JThor is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: Chains for tires in winter
