Sponsored by:
Sponsored by:
26 spline clutch
Old 09-15-2013, 08:35 PM
slickman
slickman's Avatar
Default 26 spline clutch
I'm doing the T56 swap. My current clutch is an execdy 600 and im getting just a clutch plate thats a 26 spline but its mot a excedy. Do i need to use an excedy clutch platebor can i use any 11 inch 26 spline disk?
slickman is offline
Old 09-17-2013, 01:12 AM
jimkaray
jimkaray's Avatar
I had that same issue thanks to CenterForce being too retarded to simply swap in a 26 spline hub for me. Technically the clutch and pressure plate are matched so staying with the same manufacturer & product line is the ideal choice. I explored having a clutch rebuilder swap in an new hub for me. The price would have been reasonable but he was backed up at least a couple weeks and could not be sure he had a hub that matched the old one. Luckily GForce was able to find me a compatible disk in their McLeod master catalog that was their version of the dual friction disk I was running. Its been working fine so far with the old Centerforce PP. All I did was scuff up the flywheel and PP with a coarse sanding disc.
jimkaray is offline
Old 09-17-2013, 09:46 AM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
I'd make sure the clutch/plate/hub were by the same company.
I'd go as far as to say the same exact clutch.
Matching problems are common and you don't wanna run into that when your transmission is already pulled just to have it sit longer or much worse have to do it over.
Blacksmoke is offline
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ccdguy
09-19-2015 05:20 PM
spamedic
09-09-2015 12:15 AM
Quick Reply: 26 spline clutch
