Sponsored by:
Sponsored by:
Help! throwing codes
Old 10-05-2013, 02:57 PM
Captain_N9ne
Captain_N9ne's Avatar
Default Help! throwing codes
P0174 System to lean bank 2
P0135 o2 circuit bank 1 sensor 1
P2197 o2 sensor signal stuck lean bank 2 sensor 1
P0135 o2 greater circuit bank 1 sensor 1
P0174 system to lean bank 2
Do I just need to replace those two sensors or is something else causing these problems?
I'm planning on ordering the 2 sensors from rockauto.com they got the motor craft sensors for cheap. I was told the car only has one upstream and one downstream sensor but I've read it has two up and two downstream sensors.
how many are their?
and which motorcraft part number should i be ordering? I'm seeing more then a few different ones from different stores but rockauto.com has DY1039 and DY1058, are those the two i need?
Can anybody help me??!!?
Captain_N9ne is offline
Old 10-05-2013, 02:59 PM
Captain_N9ne
oh yea, its a 05 mustang 4.0 v6
i believe is was built 11/04 if that matters
Old 10-05-2013, 03:33 PM
rbowmar
rbowmar's Avatar
how many are their?
According to Ask.com:
There are 4 sensors.
4.0L V6 Upstream & Downstream Sensor Locations
Both upstream sensors are screwed into the exhaust pipe right below the exhaust manifold flanges
Both downstream sensors are located in the catalytic converters
I hope this is useful.
rbowmar is offline
Old 10-05-2013, 05:22 PM
808muscle
808muscle's Avatar
What mods? Did you change anything recently? Any work done on the car recently? Unmetered air can cause issues.....ie any leaks of air getting into the intake that dont pass through the maf sensor.
808muscle is offline
Old 10-05-2013, 07:08 PM
Captain_N9ne
No mods that I know of, I just bought it two days ago so I don't know anything that has recently been done. I'll check for any leaks tomorrow.
Old 10-06-2013, 12:19 AM
SpartaPerformance
SpartaPerformance's Avatar
To me sounds like a vacuum or exhaust leak.
SpartaPerformance is offline
Old 10-06-2013, 09:21 AM
zentin
Banned
zentin's Avatar
take it to a dealer and they will take some money but will tell you exactly whats wrong....then you can go somehwere cheaper to get it fixed. People make threads asking for what wrong and they rarely ever get a correct response, so its better to just go to the dealer rather then spending time and money fixing whats not wrong.
zentin is offline
Old 10-06-2013, 08:18 PM
Steven Bannoura
Steven Bannoura's Avatar
Intake gasket leak? Just a guess
Steven Bannoura is offline
Old 10-10-2013, 02:12 PM
rbowmar
rbowmar's Avatar
If you have not bought your O2 sensors, I prefer to buy mine from Ford in the hope that they may be more accurate. Since mine are involved in many code issues, owning the sensor that matches the ECU seems logical.
If you have purchased the Rock Auto sensors, i would use them as I have heard few complaints.
rbowmar is offline
Old 10-11-2013, 02:53 AM
serumzgsh
serumzgsh's Avatar
serumzgsh is offline
Quick Reply: Help! throwing codes
