Getting a weird noise from my trans area - MustangForums.com
Sponsored by:
Sponsored by:
Old 10-21-2013, 07:05 PM   #1
Bullitt6996
Bullitt6996's Avatar
Default Getting a weird noise from my trans area
Hey guys,
It got cold here a week ago, and since then I've noticed my 06 gt transmission makes a hollow whirring noise first driving when cold and shifting into 1st, 2nd, and lighter at 3rd.
Once the car warms up, the noise dies down and I can barely hear it. It was transported from CA to TX about 2 months ago by an auto shipper and has had new tires and a tie rod end link replaced a week ago. Just bad timing or did someone at the shop F*** up my car? I have been told that it may be the input shaft bearing, to rebuild the trans. I have also benn told since I've not changed the fluid, it may just be old and needs fresh fluid. Car has 89k on it.
My question is how long do I have if it's the bearing? Can I drive it? Or should I get it to a shop immediately?
Any thoughts would be appreciated...
Bullitt6996 is offline   Reply With Quote
Old 10-21-2013, 07:19 PM   #2
whosniffedme
whosniffedme's Avatar
Well it's definitely not your end links, that would be physically impossible to do anything to your trans. If you can get under it and give us a video we could help you out a lot more. Otherwise, estimates at shops are always free.
whosniffedme is offline   Reply With Quote
Old 10-21-2013, 10:56 PM   #3
Rudolph Hucker
Rudolph Hucker's Avatar
mine did the same..mine was a 2005 with 20k miles..
grinding gear noises right?
the owner before me had even put some special oil in the box.
i think this how they are dude? it a manual yes?
Rudolph Hucker is offline   Reply With Quote
Old 10-22-2013, 07:43 AM   #4
Nuke
Nuke's Avatar
The trannys in these S197's are notorious for noise and I've heard quite a few that resolved cold weather issues by replacing the oil with a good synthetic.
Nuke is offline   Reply With Quote
Old 10-22-2013, 10:19 AM   #5
Rudolph Hucker
nukes dead right
i had a v6 with only 12k miles manual..same noises as the v8
reason i went over to auto was the crude clutch and gearboxes on manuals..
Starting a new project....could use some input. Matt's 95 Stang 5.0L (1979-1995) Mustang 2 10-05-2015 08:16 AM
Road trip to Sevierville/Pigeon Forge area folivier Tennessee Regional Chapter 4 10-02-2015 06:32 AM
4r70w torque converter q's guitarman376 4.6L (1996-2004 Modular) Mustang 0 09-30-2015 06:54 PM
20 inch Wheels a mistake on 2015 Mustang GT? mungodrums The New S550 2015-2017 Mustang 10 09-28-2015 11:54 PM
Need to rebuild the automatic transmission 1996 GT wraith777 General Tech 1 09-28-2015 11:49 AM
