Sponsored by:
Sponsored by:
Completely dead. Doors wont close, no lights,,
Old 11-08-2013, 11:57 PM
hardcore302
hardcore302's Avatar
Default Completely dead. Doors wont close, no lights,,
I unlocked the doors with the fob, got in, and tried to start. Every single light on/in the car went dead. Not a click or a single sound. The doors wont even close. I tried a jump, nothing.
Then after giving up and walking away with the door slightly ajar, the interior lights and radio go on! Cool, I got to start it, bam, dead again..
What could be the problem?
hardcore302 is offline
Old 11-09-2013, 02:31 AM
Murgatroy
Murgatroy's Avatar
Loose battery cable.
Murgatroy is offline
Old 11-09-2013, 02:33 AM
petrock
petrock's Avatar
Sounds like a loose battery terminal or a bad ground somewhere. Since the power came back I doubt its a fuse, although it wouldn’t hurt to check them. Good luck...
petrock is offline
Old 11-09-2013, 07:06 AM
Nuke
Nuke's Avatar
Let's assume you don't have a wet SJB.
Since it's intermittent, I concur on checking for a loose battery cable and would also remove and clean the battery terminals and cable clamps. Also, a near-dead battery can have enough capacity to light a few lights but as soon as you turn the key and throw a hefty load on it, that capacity literally disappears. A few seconds/minutes later and you have that small amount of capacity back to make you think the battery is ok until you apply another hefty load.
Nuke is offline
Old 11-09-2013, 07:42 AM
AzPete
AzPete's Avatar
Yep....what Nuke said....
AzPete is offline
Old 11-09-2013, 08:47 AM
mph07alloy
mph07alloy's Avatar
I've had a similar experience when the battery was about dead, these cars electrical systems act freaky when the battery is low.
mph07alloy is offline
Old 11-09-2013, 08:55 AM
hardcore302
Ok I will check that. It's 36 miles away at work, lol.
Old 11-09-2013, 08:27 PM
hardcore302
Thank you very much, guys! It was the negative battery terminal that was loose. Started right up! Thanks again!
Old 11-10-2013, 07:45 AM
wcgman
wcgman's Avatar
Is it possible that you're Helen Keller? lol. I was going to vote battery cable, but as usual Nuke types like a billion wpm so he beats everyone (well...besides Murgatory and petrock)
wcgman is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
mustangchef
09-04-2015 08:08 PM
amandahchase
09-03-2015 10:09 AM
cbird1177711
09-02-2015 08:51 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: Completely dead. Doors wont close, no lights,,
