Sponsored by:
Sponsored by:
08 Bullitt Help
Old 11-22-2013, 01:27 PM
E_Low03
E_Low03's Avatar
Default 08 Bullitt Help
Needing some help/advice. I have a 08 Bullitt and I removed the dual pod gauges that came with and put a stock pillar in. Only thing I did was disconnect the plug in from the obd2 port and pull the cable through. Now the issue
I noticed the reverse lights stay on and the car won't start. I have power (the headlights, interior lights, brake lights, and alarm lock/unlock all work) but the car doesn't even click. The theft light flashes at the normal 2 seconds and not rapidly. Also I no other cluster lights come on (like the odometer, engine light, etc) and I have no power to the radio or windows. What could this be?
Cliff notes: have power/headlights but no radio/windows/instrument and the car wont start, not even click.
Update: I just hit the panic to see if it works, the panic works but I couldn't turn it off/disable the alarm. Had to pull the battery to stop it.
E_Low03 is offline
Old 11-22-2013, 02:41 PM
krazykevin
krazykevin's Avatar
Sounds like a SJB issue, but I have no idea.
krazykevin is offline
Old 11-22-2013, 05:44 PM
E_Low03
E_Low03's Avatar
Sjb? What is that?
E_Low03 is offline
Old 11-22-2013, 07:22 PM
Moderator
JimC's Avatar
Since you weren't having problems previously you probably blew the fuse is all - when you unplugged the from the OBD. I think it is #8 that controls the data port and the dash, in the passenger side kick panel.
JimC is offline
Old 11-22-2013, 08:29 PM
slickman
slickman's Avatar
^^^ What he said...
slickman is offline
Old 11-23-2013, 11:20 AM
E_Low03
E_Low03's Avatar
Out of town right now, so I will check that one. I did check a few fuses yesterday (like 21, 16, 18 I believe).
I also tried the 2 different ways to "reset/reinitalize" the alarm and neither worked
E_Low03 is offline
Old 11-24-2013, 07:46 AM
07 Cervini
07 Cervini's Avatar
Have you tried to start the car while jumping off another? It sounds like it could be a dead battery.
07 Cervini is offline
Old 11-24-2013, 01:57 PM
E_Low03
E_Low03's Avatar
Tried #8, just now and it was still good. Put in another fuse just incase and it still won't do anything.
I did try to jump it off, but didnt let it charge too much before attempting it. If it was dead battery I shouldn't have no power, right?
E_Low03 is offline
Old 11-24-2013, 02:04 PM
E_Low03
E_Low03's Avatar
There is a 12v box that has a wire tapped into the ignition and on the other part of the box it has 2 green 2 red and black wires that run up toward the radiator.
Don't know if that has a part in it not starting
E_Low03 is offline
spectreman
03-31-2016 09:26 PM
JonnyBlazeGT
11-03-2015 01:10 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
JDWalton
09-24-2015 08:47 PM
Chris07GT
09-01-2015 07:11 PM
Quick Reply: 08 Bullitt Help
