06 v6 coolant leak ongoing issue
So last week I got a check engine light saying that the engine wasn't hitting operating temp- noticed i was losing coolant also so i changed the thermostat, thermostat housing, and coolant sensor and did a coolant flush- drove the car 300 miles yesterday and noticed the car leaked coolant again over night. I'm at a loss as to what to do now- any input guys?
Did you use the Ford plastic t-stat housing again? Be sure that the gasket is installed properly and hopefully you didn't over-torque the bolts. There are a number of locations that you could have a leak so the hunt is on!
A pressure test may be in order.
I feel your pain!!!! I also replaced out my thermostat housing about 6 months ago and the coolant is still leaking in the "V" of the engine. It looks like the leak is coming from the freeze plug, which is located in the "V" of engine, behind the thermostat housing. Supposedly the freeze plug can get corroded and start to push out, hence allowing the coolant to leak out when at temperature.Take a look there.
I did a cold pressure test a couple of weeks ago and it barely lost any pressure and did not leak. I am planning on doing a warm pressure test this Sunday to confirm.
I will update once I found out more...... :/
I replaced the freeze plugs in my wifey’s 3.8L earlier this year. The plug behind the passenger side motor mount was rusted pretty bad and leaking like a sieve. That is what got me started on the job. I replaced them all and in the process found two more that had pin whole leaks in them that I didn’t even know about. I replaced them with brass freeze plugs so they won’t corrode like the stockers did.
Well, after my neighbor (ex mechanic) did a warm pressure test on my Mustang, it turns out it is an external head gasket leak. It is slow and leaking out into the valley of the engine, therefore no internal engine issues will occur. Unfortunately, the issue will continue to get worse overtime and start leaking more, however as long as the leak is slow, I don't have to get it fixed immediately.
