Front crankshaft oil seal replacement?
Has anyone replaced the front crankshaft seal without the use of the special tools mentioned by Ford? I'm in the middle of the job and I got the old seal out but I can't for the life of me get the new seal installed. I tried using a socket that's the same diameter as the seal and hit the socket with a rubber mallet but I still couldn't get it in. The seal would just teeter totter from one side to the other. I need to somehow get equal pressure on all sides to press it in. I might end up buying the special tool and it's not cheap.
http://iihs.net/fsm/?dir=165&viewfil...nt%20Seal.pdft
I had to improvise but I managed to install the seal finally. I used a long bolt from the harmonic balancer install kit I rented before starting this. I put the bolt through a deep socket AND the large socket I mentioned in my original post. A washer was put between the two sockets and another one under the long bolt head. I was then able to drive the seal in by turning the long bolt.
bryan616fl
01-25-2019 09:07 PM
SteelerNation82
09-09-2015 09:06 AM
