would it be a good idea to drain coolant to 50% for winters?
My concern would be localized hot spots in the block where there was air instead of water. This would lead to unequal, non-uniform expansion rates in different parts of the engine. A recipe for a blown head gasket or cracked block in my book.
Buy a block heater and plug it in.
I'm surprised no one ever thought of this but I've always been known as the guy who thinks outside the box and gets some pretty interesting ideas! but was thinking, its ridiculously cold this last week I was wondering if you drain the coolant to half way so theres less coolant, would it help the car warm up faster? I figure with temps being below 0 most days the car wouldn't overheat and it would warm up faster and maybe run better?
So no, it won't heat up faster on a cold day, and your engine will simply overheat due to the air pockets.
If you do this, be sure to drain your oil 50% and replace that 50% with the coolant that you removed from the cooling system, all will be even and warm up super fast.
If you do this I am NOT liable for how much damage you cause to your car...
NO.
And don't be the next MarkNieb... well, we could all use a good laugh!
https://mustangforums.com/forum/5-0l...-this-car.html
as for OP do not lower your coolant 50% as it's been stated when you take your car to a shop and say you're having heating issues first thing checked is for low coolant, not to mention as stated except your engine to run much hotter then normal.
I would suggest let it run for a few minutes before you go anywhere.. I'm in crapshack winter capital of the freaking world aka Canada and even when it's -30 5min of running and it's cranking heat out.. if you don't wanna run out in the cold to fire it up then I would suggest remote start.
Faolan65
08-27-2015 06:40 AM
