Started my battery move to the trunk
I always get myself into crap.. lol
The way I'm going to do it, unless I'm at the track you won't even know there is one unless you are looking for it. I have this rear panel and I'm going to put the rod between the ribs. Only install it when I'm at the track otherwise there will be a small black rubber plug in the hole.
Ya know, i'm such an idot. I'm so wrapped up in a few projects i have going on, that i totally forgot about that.
I could run the wiring along the trunk and have everything mounted on the underside of the lid.
Just ordered the pigtail to use in place of the fuel reset cutoff switch in he drivers kick panel. This will interface to the switch mounted in the trunk as soon as I find the female connector. I found a place between the bumper and trunk were I can put a 3/16 stainless steel rod through and mount to the switch for the shutoff at the track. When the rod is removed you never will know there there for the track.
musnicki
09-23-2015 07:11 AM
