Sponsored by:
Sponsored by:
what is this sticking out my weather stripping?
Old 01-21-2014, 12:09 AM
kevsgt
kevsgt's Avatar
Default what is this sticking out my weather stripping?
There is this fabric looking thing protruding from between the A-pillar and weather stripping. It is above the side view mirrors, on both sides, and has always been there. What is it? Is it typical (2006 GT)?
kevsgt is offline
Old 01-21-2014, 12:19 AM
akdoggie
akdoggie's Avatar
Your mirrors gasket is what you are seeing. You can pop the backing covers off, and you will see 3 nuts (11mm nuts) that you can loosen and set your mirrors so that they are aligned better. Yours looks out of alignment, almost loose. Hope that helps you.
akdoggie is offline
Old 01-21-2014, 09:28 AM
bones302
bones302's Avatar
that's not what he is trying to show us.
it looks like it may be some of the foam from under the pillar cover that got stuck under the weatherstrip. You may have had it from day one and never noticed.
you may have a better idea if you pop off the a pillar cover to have a looksie.
bones302 is offline
Old 01-21-2014, 10:55 AM
vixr
vixr's Avatar
looks like its there to prevent rattling and/or chaffing paint...
vixr is offline
Old 01-21-2014, 11:34 AM
waykooljr
waykooljr's Avatar
I'm fairly certain this is the part...
Door Seal
Mine bunched up like that too, used a vinyl squeegee to push it back in but it keeps coming out. I'll probably replace it one of these days.
waykooljr is offline
Old 01-21-2014, 03:12 PM
akdoggie
akdoggie's Avatar
His mirror does look off too. Look at the top corner. That is what I first saw.
The other pic is definitely the door seal gasket.
akdoggie is offline
Old 01-21-2014, 03:18 PM
kevinmalec
kevinmalec's Avatar
I have the same black felt cloth looking thing sticking out by my driver side window on my 05. I am assuming it's some sort of insulation or something.
kevinmalec is offline
Old 01-22-2014, 05:38 AM
steel pony
steel pony's Avatar
Yes, that is typical. My 07 had it too, about in the same spot.
It's just some insulation stripping. You can fix it by removing that trim, which comes off from inside the car.
IIRC, you'll have to remove your interior a-pillar cover to get to it.
steel pony is offline
Old 01-23-2014, 06:06 PM
kevsgt
kevsgt's Avatar
So I just need to remove the a pillar trim, and then cut the fabric part? Can you point me to instructions for that removal?
kevsgt is offline
Old 01-23-2014, 06:08 PM
kevsgt
kevsgt's Avatar
Door Seal
There is no A pillar in that picture, so it confuses me. Are those parts part of the door?
kevsgt is offline
Quick Reply: what is this sticking out my weather stripping?
