CARB legal SCT tuner?
OK new owner I am a little bit confused about this whole tuning thing as it exists in California
2006 GT 39K miles with a automatic.
I have an axle-back exhaust, and I now have an Airraid intake as well. I have a unpaired CARB legal SCT that a friend gave me to tune the car because of the intake.
So since I intend to put the intake on the car tomorrow, when I use the SCT is it ready to go out of the box. If I need to get a tune from SCT how do I make sure that I get a California CARB legal one. I feel like all the tunes should be on the SCT already because people would just mess with them if they were unlocked.
In a perfect world I would get just a BAMA tune and go from there but keeping the car legal is the end goal until I can find a used Vortech kit cheap enough.
Load any tune you want, then when you need to make CARB happy you go back to the stock tune, that's what your tuner is for. I don't know what your worried about, I have long tubes, cams and a blower, and a very aggressive tune and have had them since 2010, and were still rolling along.
I assumed that once I wrote a non stock tune onto the ECU that it would be detectable as such even if I put the stock tune back on.
If you are worrying about Smogging it, Set it to stock a few days before you go in and drive it so everything is working properly. If they say anything about the ECU tell them you cleaned your battery terminals, that is what my friend with the Lightning does when he takes the chip out of his and puts the stock pulleys back on.
I knew there was a reason I left California 20 years ago
You can get an emissions tune from bama as well a performance one. The smog people don't check if other tunes have previously been loaded, just that all the sensors are on and ready, and that no check engine light is tripped (as far as the obdii test goes). Have fun and reload the stock or emissions tune when it's time. You should check to see if the Airraid CAI has a CARB number, if it doesn't, then you'll have to install the stock airbox also at smog time.
Plus, you can always revert back to stock a few days before testing. That will rebuild the KAM memory, assuming you drive enough miles in those few days.
Hope this helps!
Shane
bradleyb
11-27-2015 07:50 PM
