Sponsored by:
Sponsored by:
CAI issues
Old 02-04-2014, 01:59 PM
stlcity77
stlcity77's Avatar
Default CAI issues
Just installed a Roush CAI on my 05 V6 and i keep getting the wrench symbol and a check engine light. Car drives fine for a few minutes then it feels like its going to stall and the wrench pops up and it drives different after that. Do I need a tune? I followed the instructions exactly and disconnected the ground cable from the battery as instructed before install. This is my first mod to my car and I am new to all the tuning aspects. I use regular cheap gas and its been very cold in PA recently. Please help any advice is appreciated.
stlcity77 is offline
Old 02-04-2014, 02:04 PM
Moderator
JimC's Avatar
Yes you need a tune for the CAI. You are running lean and the computer is shutting the engine down to protect it
Sent from my SPH-L720 using IB AutoGroup
JimC is offline
Old 02-04-2014, 06:51 PM
J7erry
J7erry's Avatar
Shouldn't need a tune for that CAI. I put the exact same one in mine. Did you hook up the MAF sensor or damage it? That seems more the problem
J7erry is offline
Old 02-04-2014, 07:11 PM
Csrt4to5.0gt
Csrt4to5.0gt's Avatar
Yeah, you shouldn't need a tune for that intake. It's not even required on the new 5.0. Like mentioned earlier, your MAF could've gotten damaged or even dirty. They can be very sensitive when exposed to the elements. I'd start there first. Or just go back to stock first and see if the problem clears up. I see you live in Pa, too....maybe moisture got in there.
Csrt4to5.0gt is offline
Old 02-04-2014, 08:24 PM
Nuke
Nuke's Avatar
Even a no-tune-required CAI can throw a code and extreme weather conditions can increase those chances. Regardless, A no-tune-required CAI gains little to no power gain; perhaps 3-4 RWHP on your 4.0. A good custom tune with a tune-required CAI yields roughly 15-20 RWHP on that V6.
Nuke is offline
Old 02-06-2014, 01:07 AM
808muscle
808muscle's Avatar
Go over your install again and make sure you have no air leaks. Any unmetered air entering your motor is a bad thing. Get some maf cleaner spray and clean the maf. Dont use anything but maf cleaner to clean it to. Dont touch the sensor part of it...its very fragile. You should be able to figure it out...has got to be something simple.
808muscle is offline
Old 02-17-2014, 06:33 AM
stlcity77
stlcity77's Avatar
Ok so I went back to stock setup and I am still getting check engine light with the wrench emblem. I have not tried cleaning the MAF sensor yet but that will be my next step before i start possibly replacing certain components. Also I noticed the PCV valve was loose when it was installed on the CAI and wasnt getting a good seal. I have been told this is a vacume hose so I wonder if that could be the issue? Any help is appreciated thanks
mapitts
05-15-2016 02:57 AM
firecoyote
09-27-2015 02:37 PM
jc409
Convertible Tech
09-26-2015 08:28 AM
Ghost_Conscience
09-23-2015 02:17 PM
LivingInThePast
09-16-2015 12:20 PM
Quick Reply: CAI issues
