xpipe for Mustang?
xpipe for Mustang?
Hey guys, on my 2007 roushcharged mustang im looking to go with the best x pipe at a reasonable price (under $500) to compliment my Flowmaster american thunder series mufflers? any ideas?
There are all just that...a pipe...
What determines the price would be the diameter of the piping and the material it's made of...
Most of the x-pipes you'll find will need some slight modification or cutting to fit to the stock exhaust piping.
What the x-pipe will do for you vs. an h-pipe, is give you less restrictive airflow but will most likely cause more drone.
So the questions that needs asked right now is:
What setup are you running from the headers to the mufflers?
Stock or aftermarket?
If aftermarket, what size tubing are you running?
Don't people usually pair H pipes with chambered mufflers and an X with straight through mufflers?
Something about sound, drone, yadda yadda. Someone more versed than me will hopefully chime in here.
Of course, don't listen to any of the above, I ignored it myself and put an H pipe on straight throughs.
For the 3v 4.6 I only have experience with the straight threws. But on my 2002 gt I had a h pipe with magnaflows chambered and they drowned like crazy then I had some slp lm1s and they were worse. But with this car I have had zero drone even with the o/r x pipe and cams.
I've got long tubes, x pipe, and glassbacks, and there's a drone. It's nothing bad, it's able to be lived with.
If you're getting an xpipe, get a matching brand header at the least. And go with BBK.
http://www.uprproducts.com/mustang-o...x-pipe-05.html
There's two ways you can go with this.. If you decide to get LT headers after buying a midpipe, it'll be a waste of money because you'll need the "shorty" midpipe that matches the brand.
If you don't want LT headers at all, I'd go with bassani.
BTW I have LT's, catted X, and Corsa muffs... No drone hehee.
