washer fluid spray nozzle removal
My dad has a 2011 v6 and lives a few states away, so unfortunately I can't help him too much. Has anybody removed the spray nozzles? Basically the hose popped off and from what he's told me, you can't remove it from under the hood with the insulation pulled. Any help is appreciated.
The Squirters route through the hood frame and connect to the rest of the tubing going toward the passenger side of the hood then back down into the fender well.
To disconnect the squirters... simply turn the plastic ring connectors from the tubes heading towards the squirters and gently pull.... They'll come apart.
Then with a flat head screw driver you apply gentle pressure at the squirter nozzle under side of the hood and pry out... it will pop out with the 4 inches of tubing attached to it.
Not sure if that tubing is what popped out, if it is...then once the disconnect is done you'll be holding that piece. So When you pop out the Squirter... maybe glue it back???
jwog666
12-27-2021 08:09 PM
09-25-2015 06:42 PM
