Sponsored by:
Sponsored by:
Old 10-23-2015, 05:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
replacing gauge stepper motor?
Old 02-11-2014, 07:38 PM
RazorGT
RazorGT's Avatar
Default replacing gauge stepper motor?
do you have to replace the whole gauge cluster or can you buy an individual stepper motor for the gauge thats not working properly?
do parts stores like autozone sell them? what exactly are they called?
is it possible to get an aftermarket one that is more hardy then the faulty oem ones?
RazorGT is offline
Old 02-11-2014, 08:43 PM
danzcool
danzcool's Avatar
Plenty of them on ebay.
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
danzcool is offline
Old 02-11-2014, 10:21 PM
2007CalSpec
2007CalSpec's Avatar
I replaced a stepper motor once. It's better than OEM. Here's a link...
http://www.ebay.com/itm/1-x-2005-FORD-MUSTANG-SPEEDOMETER-STEPPER-MOTOR-X25-589-X25589-X25-589-X-/280820163266?pt=Car_Audio_Video&hash=item41622fa2c2&vxp=mtr
Here's a How-To on replacing them. Pretty easy really.
http://www.ratstangrestoration.com/S...ent%20Pack.htm
2007CalSpec is offline
Old 02-11-2014, 11:18 PM
cema93
cema93's Avatar
lets make this quick and simple. go to ebay. find someone selling the little stepper motors. the code on them should start with an X I think. buy 4 or 6 six depending on ur cluster and take the old ones off and put the news ones on. everything will work fine.
cema93 is offline
Old 02-12-2014, 04:33 AM
RazorGT
RazorGT's Avatar
thanks guys
i rather have a shop do it, so if i just got the motors off ebay, they should know what a stepper motor is and be able to open the dash and replace them?
RazorGT is offline
Old 02-12-2014, 01:24 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Don't bother going to a shop to have stepper motors replaced. The labor will be too costly and most mechanics shops are not good electrical shops. Instead, go to ebay or search online for a rebuilt gauge cluster that uses upgraded stepper motors and just replace the gauge assembly yourself.
Derf00 is offline
Old 02-12-2014, 02:18 PM
krazykevin
krazykevin's Avatar
Its not too difficult, but if you are really not comfortable doing it, then I would take it to an electronics repair place before I took it to a car shop. You can easily take the cluster out and bring it to an electronics repair place to have them re-solder the motors on the circuit board. Car shops normally do not do much work on circuit boards, they just replace the entire part.
I replace all of the motors in mine myself. I wouldn't recommend it unless you have experience soldering, but if you do, then it is easily do-able.
krazykevin is offline
Old 02-14-2014, 02:04 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Yeah, I forgot, there are shops that specialize in automotive electric. It would be a good alternative and they may even have upgraded stepper motors in stock to replace the bad ones on your cluster if you just bring them the cluster.
Derf00 is offline
Old 02-25-2014, 09:01 PM
Captain_N9ne
Captain_N9ne's Avatar
Does anyone know if the replacement stepper motors should be x27.589 or X25.589 for a 05 v6? i have the 4 gauge dash if that matters.
Captain_N9ne is offline
Old 02-26-2014, 10:07 AM
StantheMan
StantheMan's Avatar
X25.589 There is a lot of good info in the above posts, set up a neat work area, follow the instructions on the post, and give it a try, a new cluster is a little more than a couple hundred bucks if you really screw up, which is most likely not much more than hiring it done. Just take care not to scratch the faceplate, use light cardboard(like a matchbook) to protect faceplate while prying up the needles.
StantheMan is offline
Quick Reply: replacing gauge stepper motor?
