Sponsored by:
Sponsored by:
New 2014, adding exhaust void warranty? Oil question too
Old 02-25-2014, 07:54 PM
dseg
dseg's Avatar
Default New 2014, adding exhaust void warranty? Oil question too
As the title says it, I just bought a new Mustang GT and wanted to add the Roush axle-back exhaust to make it sound a little meaner. Would this void the warranty? It has 500+ miles on it.
Also, what oil should I be using? I usually use synthetic AMSoil but not sure about the 0w-30? 5w-25?
dseg is offline
Old 02-25-2014, 08:12 PM
2011V6Nicole
2011V6Nicole's Avatar
No an axle back exhaust will not void your warranty, and as for the oil it should say on the cap and in your owners manual
2011V6Nicole is offline
Old 02-25-2014, 08:13 PM
Xann27
Xann27's Avatar
first, the oil, i use the standard motorcraft synth blend. thats what ford built the motor around. doesnt hurt going to a full synth, but 8 quarts per change... yikes! i would only trust full synthetic oils such as Mobile 1, or Royal purple. RP is hands down the best. but... some places its about $11 a quart.
warranty answer. If you add an axle back exhaust, the only way ford can void your warranty is if the issue caused IS AND CAN BE PROVEN to be caused by the part added. if you add an ECU tune, and the transmission takes a crap, they CANT void the warranty on the tranny. but if you say, add a bigger throttle body and intake, and you have a problem with the engine itself, they can toss your warranty out the window if they want.
so, if you add the axle backs, and it causes some kind of RARE backpressure issue that jacks up your catalytic converters, yea, they can void the warranty on that. make sense?
Xann27 is offline
Old 02-25-2014, 08:25 PM
70monte
70monte's Avatar
I have a 2014 GT and installed the Roush AB at about 600 + miles. I have not read anyone getting their warranty voided just for an exhaust. I'm not going to worry about it.
As far as oil, I only have 4,400 miles on my car and are still running the factory fill oil. I plan on changing it soon using the Motorcraft blend.
Wayne
70monte is offline
Old 02-25-2014, 08:58 PM
Nuke
Nuke's Avatar
The blend that comes in the crankcase from the factory is fine for 5k - 7k miles. If you want to go longer, then full syn is fine. Stick with the weight recommended in the OM. I typically run full syn in all my vehicles to 10k or more miles, even my tow vehicles. They've all went well passed 200k miles with no engine issues or performance problems. And my current 4 vehicles will do the same.
Forget about the warranty. That's betting your car will crap out. The law requires the dealer to prove that the non-OE part caused the failure/problem. Most dealerships like to intimidate the car owner. Pull your panties up and grow a set. F**k the warranty. You'll never enjoy the car's potential if you're a warranty wuss.
Nuke is offline
Old 02-26-2014, 08:39 AM
dcarlinf1
dcarlinf1's Avatar
^^^^ LOL!!
No, an axle back will not void your warranty. Period.
dcarlinf1 is offline
Old 02-26-2014, 08:48 AM
jhawkr
jhawkr's Avatar
Says the guy with a 2007 and no warranty! It's a legit question. It's possible to cause warranty issues but not likely. You could go with Ford Racing axleback and insure you would never have issues. I'm going to keep my 2014 stock. I found that with about 20,000 miles, the stock exhaust system on my 2010 opened up quite a bit over new levels. I expect the 2014 might do the same.
jhawkr is offline
Old 02-26-2014, 10:18 AM
outceltj
outceltj's Avatar
Who buys a stang and worries about a warranty. I bought mine new and had a tune in a few months.
outceltj is offline
Old 02-26-2014, 11:13 AM
jz78817
jz78817's Avatar
people who don't have bottomless pockets. Like, most of us.
jz78817 is offline
Old 02-26-2014, 11:32 AM
ModBargains
Former Sponsor
ModBargains's Avatar
Thanks to the Manugson and Moss warranty act, an aftermarket part installed on a vehicle cannot be grounds for voiding a warranty. The dealer must prove that the aftermarket part installed on the vehicle is the honest cause for any damages that might be claimed under warranty. FTC has confirmed that the Magnuson and Moss warranty act makes it illegal for companies to void your warranty or deny cover under the warranty simply because you used an aftermarket part.
You can find more info about it here, or you can google Magnuson and Moss Warranty act:
http://www.sema.org/sema-enews/2011/...ermarket-parts
ModBargains is offline
Quick Reply: New 2014, adding exhaust void warranty? Oil question too
