Water Sloshing in Rear
Can anybody help me out? When it rains hard, the few days following I can hear water sloshing around in the rear of the car. It sounds like I have a few gallons in the trunk. I'm looked in the trunk itself and it stays completely dry. However, when I hit the brakes I can hear water moving around...
Convertible or hard top? Also I haven't had mine long enough to really worry about so I don't know where all the drain hoses are at but I think you should take yours in & have it looked at under warranty. If there's water sloshing around you don't want it standing too long.
Its a hard top. Good idea, that's my plan on my day off next week to take it in and get it serviced for the first time since I've had it. Also, I'll ask about the "water" noise coming from the rear.
Can you also hear it from outside your car? Like if you are pulling into a garage and you step out and close the door?
If possible try not to fill your gas tank all the way (only do halfway) for a bit and see if you can still hear it.
Hear is a link to someone else that had a similar problem. Maybe it will help you with your issue.
http://forums.themustangsource.com/f...-panel-526799/
Wayne
Wayne
wishinsky
09-21-2015 09:48 AM
09-16-2015 07:53 PM
