do i need alignment after adj phb?
If you don't loosen it, the bolt for the PHB brace is still squeezing that bracket together a little, which is making it seem like the gap is too narrow. The axle-side bracket only has the PHB bolt, so when that's out there aren't any other fasteners squeezing that bracket together.
Did you measure your axle centering with the car weight fully on all four wheels? The LCAs are not quite parallel, so any axle offset at least theoretically affects your axle's thrust angle and will cause you to have to steer it a tiny bit to stay straight. If this is the case, and you did not touch any other rear suspension fasteners or components, your axle is probably a little too far to the right.
Norm
Norm
Also i wanted to add that in instruction it says to "It is important to adjust both sides equally while maintaining the spacing difference (the long threaded end should be roughly
35mm longer than the short end)"
what do they mean by maintaining equal space difference?
I was watching bmr installation video and others never mention about lossening the brace bar mount. Anyways I finally got it out ealier by wacking it. Its weird the passenger side doesnt drop rather tight compared to the driver side when you take the bolt out. I had trouble putting it in and out, seems like the chassis frame mount gap is too narrow and had to bang it in.
You take it to an alignment shop, they wont know what to do! ..unless someone there is familiar with these cars and about an adjustable panhard...
there is NOTHING to align.
There is ADJUSTMENT, that as described above, can easily be done.
The car won't pull one way or another as a result of this; has nothing to do with steering.
I didnt know so i force it in, did scrap alittle mental off the phb end and chassis mount when i force it in. I should be okay. My thrust before was -.18 and i was told by american muscle to get a panhard bar to fix the rear axle offset which i did. I had to make about 1/4 of an inch adjustment on the panhard bar. If anything it should of help, i guess ill need to visit an alignment specialist.
Norm
Im a newbie when it comes to cars, theres still much to be learned. I find it weird when people says no alignment needed when installing these phb. Doesnt moving phb side to side change thrust point?accuracy going off by wheel well? wouldnt adjusting it on an alignment machine give you the closest 0 thrust.
Norm regarding to the installation instruction that was only part that threw me off. the longer end which is passenger side has same amount thread after adjsuting as driver side.
Do the bushings in your OE PHB look distorted in any way?
Norm
I don't think it's common for people to have to tweak thrust angle when all they've done is swap in an aftermarket PHB and adjust it, but then again it could come down to how sensitive the individual is for a slightly off-centered steering wheel vs the desire to get the axle visually centered.
Norm
Norm
I'm looking at bushing deterioration as a possible cause of thrust angle error you had before that might have gone away with the new PHB's bushings/sphericals. I also suspect this as a possible explanation for why people seem to find far more axle shift when they lower their cars than can be explained by triangle geometry alone.
The reference I found ( http://www.ttsroadsport.com/4_wheel_...t_glossary.asp ) differs on sign convention, and according to this a negative thrust angle would be consistent with the car trying to drift to the left (until you correct that by steering to the right).
Norm
A positive thrust angle is one that points to the left.
A negative thrust line is one that points to the right.
Norm
Good news, thrust is not out of whack rather its now -.03 way better than before. It was previous toe setting that upset the steering.
UPDATE* I had to revist tire kingdom ealier due to steering wheel slightly sitting left while driving striaght down the road. He went under and adjusted the toe setting on both side but he didnt have the reflector on the wheels. He said it wasnt neccessary and sure it would not mess up my spec. Should i be worried? Hes a very knowledgeable alignment specilist from what i can tell and car drives striaght.
Bad news, rear tire slightly cupped, not by shock so they think its the car characteristic or lack of rotation in 10k miles since purchase lol
