Axle Interchange.... - MustangForums.com
Old 04-24-2014, 05:19 PM   #1
86HOGT
86HOGT's Avatar
Default Axle Interchange....
Will a 10-14 rear axle fit an 05-09?
I knew my car was hit before I bought it but after seeing the alignment today there's one degree of toe out on the rear wheels.
86HOGT is offline   Reply With Quote
Old 04-24-2014, 06:09 PM   #2
86HOGT
86HOGT's Avatar
The left rear was -1.4 deg and the right rear was at +.4 deg.
Old 04-24-2014, 06:26 PM   #3
Moderator
JimC's Avatar
It's the same axle, no difference in the mounting.
Are you sure it is straight? If it is used and off a wreck maybe it is twisted.
JimC is online now   Reply With Quote
Old 04-24-2014, 06:42 PM   #4
86HOGT
86HOGT's Avatar
The axle shaft was replaced and it explains the difficulties I had with installing the watts link.
Old 04-24-2014, 06:45 PM   #5
86HOGT
86HOGT's Avatar
The right rear had no camber so the hit probably came at an angle from the front
Old 04-25-2014, 06:37 AM   #6
Moderator
JimC's Avatar
Although you replaced the axle shaft, it is possible that the axle tube itself is bent or twisted. That could account for the difference side to side.
Old 04-25-2014, 07:03 AM   #7
pascal
S197 Section Modder-ator
pascal's Avatar
Most likely the axle tube.
pascal is offline   Reply With Quote
Old 04-25-2014, 10:35 AM   #8
86HOGT
86HOGT's Avatar
Yeah that's what I figured. The car was wrecked and fixed before I bought it. And when I seen how the left rear tire was wearing slightly more on the inside I had my suspicions. Looks like I'll be replacing the entire housing in the near future.
Makes sense with all the clearance issues I had with the watts as well
What other parts should I be concerned about if my pinion bearing went bad? KingRando 2005-2014 Mustangs 5 10-02-2015 09:06 AM
Car Suspension problems? marc954 4.6L (1996-2004 Modular) Mustang 2 09-29-2015 12:18 PM
2 or 4 wheel alignment? lincolnshibuya V6 (1994-2004) Mustangs 1 09-24-2015 11:46 PM
Steeda S550 Mustang GT Axle-Back Exhaust with Aftermarket H-pipe (15-16 GT) tj@steeda Steeda Autosports 0 09-24-2015 10:18 PM
Steeda's S550 Mustang GT Axle-Back Exhaust System - Video Inside tj@steeda Steeda Autosports 0 09-10-2015 09:39 PM
