Sponsored by:
Sponsored by:
New Wheels, New Tires, Car Still Shakes (F**king Pissed)
Old 06-02-2014, 10:56 AM
  #51
Rudolph Hucker
Rudolph Hucker's Avatar
i have had the same trouble..these cars need to have perfectly balanced wheels..
i have had mine balanced 3 times in the last 4 months..each time they went slightly out..on any other car this isnt a problem..on these it is..
Rudolph Hucker is offline
Old 06-03-2014, 01:00 PM
  #52
whosniffedme
whosniffedme's Avatar
That doesn't really make sense though, I don't see how anything on my car could affect the way aftermarket wheels and tires work.
whosniffedme is offline
Old 06-03-2014, 01:21 PM
  #53
gmoran1469
gmoran1469's Avatar
You sure it's not just cold tires and you are feeling it translate through the steering wheel? I run NT555s and even when my car just sits overnight (12hrs or so) I get a little wheel shake until I drive it and warm up the tires. Just a byproduct of stiff suspension and tight steering plus wide wheels.
gmoran1469 is offline
Old 06-03-2014, 01:50 PM
  #54
whosniffedme
It's definitely not that. On paper, they're going out of balance.
Old 06-03-2014, 02:49 PM
  #55
bryan67
bryan67's Avatar
I dont understand how a set of tires can keep going out of balance. If the tires arnt spinning on the rims and the wheel weights arent moving or being thrown. You either got some terribly bad tires or some out of round rims. You sure that the rims are getting mounted properly?? Been driving and racing cars for 20+ years and never have heard anyone have as many tire issues as you are. Gotta be something going on. Know anyone else locally with a mustang you can try swapping Tires and rims with?? Ever consider trying Dyna Beads??
bryan67 is offline
Old 06-03-2014, 07:52 PM
  #56
AzPete
AzPete's Avatar
Almost sounds like something floating loose inside the tire.
Rough roads with potholes can be hard on tire balance.
Might see if a shop has some used tires to try for a week.....
How much out of balance by the weight amount is it.....or do the weights have to be moved to a new location each time.
Very hard to say no weights lost unless records of amount and location are kept......especially on clean wheels.
AzPete is offline
Old 06-09-2014, 03:37 PM
  #57
Derf00
Gentleman's Relish
Derf00's Avatar
Belt separation could give the "appearance" of tires constantly needing rebalance. What tire pressure are you using? Too much pressure can certainly unbalance tires on a rough roads.
Derf00 is offline
Old 06-10-2014, 12:13 PM
  #58
Simon1
Simon1's Avatar
After reading through most of this I would have to say it's going to be something else besides a tire/wheel.
Simon1 is offline
Old 06-11-2014, 10:16 PM
  #59
alaskarider
alaskarider's Avatar
Check the rear axle and front hub bearings and flanges for damage or runout. I work on crown vics for a living and the troopers make HARD turns and occasionally impact things. I've had many do what you describe with a bad rear wheel bearing or flange. You can pm me if you need any advice on how to. You have to trust diagnostics each step of the way and dig deeper. There are no voodoo problems but some you have to go below the surface to fix.
alaskarider is offline
Old 06-12-2014, 12:06 AM
  #60
07BLACKGT
07BLACKGT's Avatar
I've been through this nightmare... I went through 3 "road force" balances until I found a place who actually knew what the hell they were doing. If you have a popular wheel/tire shop in town that specializes in the "22's and betta" type of deal, they may be worth checking out for a balance. Also make sure your tpms sensors have not come off the bands! That was one of the main problems with mine.
07BLACKGT is offline
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
cema93
08-10-2015 09:35 PM
Mr. D
Wheels & Tires
08-08-2015 05:43 AM
Quick Reply: New Wheels, New Tires, Car Still Shakes (F**king Pissed)
