Sponsored by:
Sponsored by:
changing pinion seal, what size socket?
Old 02-05-2017, 07:59 PM
  #21
Menace
Menace's Avatar
Originally Posted by tbear853
Good point to update .... shortly after my above post (over 2-1/2 years ago) I did modify my '08's axle vent with a hose after removing the OEM vent with check valve disc .... which has a small spring above holding the disc against the hole (maybe '06 they used a piece of sponge rubber to do same sealing job?) .... so that there is a pressure threshold that must be overcome for it to vent built up pressure.
I used a 3/8" hose bib, smoothed the threaded end and used a die to rethread it 7/16-20 and attached my hose to that. I ran hose up and over out of harms way and down into a frame tube (much like described by moosestang with pics above).
So far .... there have been no further signs of leakage, no wetness, and no drips hanging on the housing. Seal is in my spares box.
That is good to know, I bought some 3/8 hose and a clamp to do this modification to mine. I just have to get the old vent off and disassembled.
Menace is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
Urambo Tauro
09-07-2015 12:47 PM
mustangsrforever!!!
08-06-2015 12:04 PM
Quick Reply: changing pinion seal, what size socket?
