changing pinion seal, what size socket? - MustangForums.com
Sponsored by:
Sponsored by:
Old 04-29-2014, 08:02 PM   #1
moosestang
Default changing pinion seal, what size socket?
i tried goggling it and I see two different answers? Is it 1 1/8 inch or 1 1/16?
moosestang is offline   Reply With Quote
Old 04-29-2014, 08:57 PM   #2
tbear853
tbear853's Avatar
Quote:
I'm not sure which it is ..... yet ..... but it looks like I will know pretty soon.
My '08 is leaking just a hair there as well, seems to be a common malady some how? I have a '01 Mercury GM and '92 and '95 Thunderbirds all with 8.8 rears and not a drop but this '08 Mustangs is leaking.
tbear853 is offline   Reply With Quote
Old 04-30-2014, 06:26 AM   #3
moosestang
It's looking like 27mm or 1 1/16 is correct. I might have both, I know I have 1 1/8.
Old 04-30-2014, 07:59 AM   #4
dlazrael
dlazrael's Avatar
it's a big ****... had to get one from the hobby shop when I put the Alum D/S flange on lol
dlazrael is offline   Reply With Quote
Old 04-30-2014, 02:01 PM   #5
moosestang
Well I had to spend the first half of the day at the dentist, so it looks like Friday I will start on it. I probably need to remove my mid mufflers to give me enough leverage room to get the pinion nut off, so this will give me all day Saturday to finish up.
Got a 27mm socket from lowes for $7. bottle of white out from CVS for $2.99 to mark everything. I'm going to count turns and put the nut back on just how it came off.
I had to get the pinion seal from ford, discount auto told me it was dealer only.
My leak was most likely cause by my clogged vent. The vent would puke oil and my dirt road would stick to it like glue. I'm going to pull the vent and see if I can't rip the top cap off and install a length of hose.
Old 04-30-2014, 03:21 PM   #6
dlazrael
dlazrael's Avatar
Impact gun makes the removal MUCH MUCH easier
Old 04-30-2014, 05:21 PM   #7
moosestang
Quote:
If I had one, then I might use it. still wouldn't want to use it to tighten it back. It'd be to easy to go past the original spot.
Old 04-30-2014, 09:19 PM   #8
Carcrazycorey1
Which advance did you go to? I work at one in Gainesville and I know for sure we have them because I just recently looked up how much one is at work because my 05 GT leaks a little from the pinion seal too.
Carcrazycorey1 is offline   Reply With Quote
Old 05-01-2014, 02:37 AM   #9
drewsky
Quick question? I just had my pinyon seal replaced last month, maybe due to lowering and or the vent clogged, I also lived on a dirt road till a few weeks ago. Can you get to the vent from the outside of the axle, or have to come though the inside of the pumpkin axle housing? I know (if I remember correctly) it's a bout a foot over from the center diff on the passenger side. But I haven't been under there to inspect in a while or look at it closely, I want to clean this thing out ASAP! And also, if you haven't figured out the socket size I would just go to sears or ace hardware ect... And buy a few sizes and just return the ones you don't need, or return all of them when you done haha
drewsky is offline   Reply With Quote
Old 05-01-2014, 02:21 PM   #10
moosestang
Quote:
It just unscrews from the top of the axle tube. I think it's a 13mm wrench, maybe smaller. I took mine out before to make sure I could blow through it.
**New...from NAT! 2015 Ford Mustang MRT Rear Window Louvers**Free shipping! NorthAmericanTuning Vendor For Sale / Group Buy Classifieds 5 11-09-2016 11:45 AM
**2015 Ford Mustang MMR Flow Forged M350 Wheels Package**Free shipping! NorthAmericanTuning Vendor For Sale / Group Buy Classifieds 3 11-09-2016 11:44 AM
**New from NAT!2015 Ford Mustang MRT Rear Window Louvers**Free Shipping! NorthAmericanTuning The New S550 2015-2017 Mustang 3 03-18-2016 11:21 AM
1995 Mustang GT- 8.8 Overhaul Urambo Tauro 5.0L (1979-1995) Mustang 22 09-07-2015 12:47 PM
Mustang Club in Abington/Huntington Valley mustangsrforever!!! Pennsylvania (Philly/Tristate) Regional Chapter 0 08-06-2015 12:04 PM
