Sponsored by:
Sponsored by:
Meguiar's leather cleaner damaged seat
Old 05-18-2014, 04:35 AM
02redv6stang
02redv6stang's Avatar
Exclamation Meguiar's leather cleaner damaged seat
Like the title says the cleaner appears to have taken the dye off of my drivers seat. I even tested in a different area and all seemed to be fine. But when I started to clean the seat my rag started turning more and more tan. I've contacted Meguiar's to see what they can do about it. After a google search I found I'm not the only one this has happened to. Just thought everyone might want to think twice about using their leather products!!
02redv6stang is offline
Old 05-18-2014, 06:16 AM
Rudolph Hucker
Rudolph Hucker's Avatar
only the middle section is leather..only the front seats..rear seats and sides of the front seats is just vinyl...i use amoural on that section
Rudolph Hucker is offline
Old 05-18-2014, 07:51 AM
02redv6stang
Well that's all fine and dandy but the part that was harmed is actual leather
Old 05-18-2014, 10:15 AM
RetiredSFC 97
RetiredSFC 97's Avatar
Sure it's the conditioner and not cheap leather? My manual says to clean the seats to just use a rag and water IIRC.
RetiredSFC 97 is offline
Old 05-18-2014, 10:33 AM
Rudolph Hucker
i oil mine..only the middle section.
then amourall the rest..works well keeping all supple
Old 05-18-2014, 11:20 AM
2cokeman
2cokeman's Avatar
pics?
2cokeman is offline
Old 05-18-2014, 02:01 PM
steel pony
steel pony's Avatar
Not saying what you have described isn't true or not, but given the year of the Pony you have listed, i'll throw out these questions that need answered and would most likely be posed by Meguiar's too.
*Did you follow the instructions on the product?
*What did you use (type of rag) to apply the cleaner with?
*What was the previous condition of the interior prior to applying the product?
I say this, because as the other posters have mentioned, only the middle of the seats are actually leather. The outer sides of the seats are vinyl, which are prone to cracking and normal wear and tear over the life of the car (especially the front seats on either side of the center leather section). If they were in some state of "wear", then it is very likely that some of the dye would come up, depending on how you "applied" the cleaner.
*You tested it in a different area...where? Was this area in the same condition as the area that the dye was lifted from? (see previous comment)
*Is this the first time applying this product to the area?
*Were there any other chemicals/cleaners/etc applied recently to the same areas?
Pics would definitely be helpful to gauge the wear or condition of the seats too
steel pony is offline
Old 05-18-2014, 03:43 PM
Nuke
Nuke's Avatar
Did Ford offer tan interior in the '07? It's been awhile and I don't recall.
Nuke is offline
Old 05-18-2014, 06:09 PM
Art161
Art161's Avatar
Would you believe "medium parchment"?
Art161 is offline
Old 05-18-2014, 06:12 PM
Cristoff
Cristoff's Avatar
Almost impossible to tell without a pic of the area.
Cristoff is offline
Quick Reply: Meguiar's leather cleaner damaged seat
